Originally posted by mikegar
View Post
Post Your M/S5X 24V Swap Setup
This is a sticky topic.
“Speed has never killed anyone, suddenly becoming stationary… that’s what gets you.”
― Jeremy Clarkson
Euro 318is M50 build thread
Originally posted by Aguedae30 View Postany dyno numbers? looking forward for some similar setup,thanks!Originally posted by FerdinandI carry a cheap pressure gauge in my glovebox with which to manually check my tire pressures, but I keep forgetting that in the USA glovebox space is sacred as it is reserved exclusively for the purpose of storing handguns.
DIVING BOARD DIVISION DIVISION IDIOT
Hey R3v, my recently complete swap setup... yet to be road worthy as i have a differential, and getting an exhaust fabled up left. anyway, here it is, this has worked for me so far...
1. Engine
Bought an S50B30 US with 101xxx miles, 3.5 inch HFM, and a Silver label 413 that i later bought a TMS EWS delete chip plus upgrades. Im running UUC underdrive pulleys, no AC, Stewart water pump, bavauto coil packs, silicone full 3.5" intake, and some other various goodies
2. Engine Wiring
I used the original S50 harness and had it rewired by Markert Motorworks. Very professional, good service, Dave did a great job. Was also very helpful after the fact when i had a starting issue that ended up being unrelated to the harness... (i had my harness hooked up to the power block wrong, and then i also had fuel lines mixed up...)
3. Drivetrain
Original ZF310 that came with the engine, 101xxx miles. Ill be using a 97 M3 driveshaft with a new CSB and large guibo, all linked up to a 3.23 or 3.25 LSD when i can get my hands on one.
4. Shift Lever and Linkage
E36 stock linkage fit perfectly with the E30 chassis mounting bracket. Looking into getting a UUC Evo SSK once i get it drivable.
5. Motor Mounts
AKG poly 24v mounts. Worked very well for me, easy to get on. Plus, word is they will last much longer that the e28 green ones.
6. Brake Booster, Master Cylinder, and External Reservoir
Zionsville autosport brake booster (modified e21 booster i believe) with stock MC and Res. I measured cut and bent all new brake lines to delete my ABS system (which was broken). Markert was able to completely leave out any wiring for ABS in my harness on request. Will be getting a 25mm MC when I have the money to buy and find a complete MZ3 rear end for 5 lug.
7. Steering System
Zionsville 2.7 lok-lock kit. i believe its a z3 1.9 rack with custom made linkage from zionsville. Had to readjust my steering column to fit the new link due to my cars airbag system (also deleted) but it fit in the end. Also have a MOMO tuner steering wheel 350mm with a BMW logo horn button.
8. Cooling System
Mishimoto radiator, samco silicone hosing, stewart water pump, SPAL 16 high performance pusher with no puller, 80/88cc fan switch, 80cc thermostat, zionsville e36 fan shroud coolant reservoir. What i did was i took the reservoir off the fan shroud and fabs up a custom bracket to mount it behind the passenger side headlight. You can see it right there in the picture.
9. Exhaust System
Raceland longtube headers and a Stromung E30 Catback is what i currently have. Im going to get a Y pipe welded to the race lands into a 3" single ss pipe back into another y pipe and into the stromung.
Various other upgrades I'm sure I'm forgetting such as stainless clutch line, Bimmerworld comp FCABs, and my yet to be completed custom fiberglass CAI box, etc, but thats basically it. Ive been collecting parts since november last year, pulled the M20 in May of this year, and got it running 2 days ago, July 25. Hope you enjoyed, i have pages and pages of sources and possible setups saved from months of researching this stuff, but this is my setup so far. Thanks for looking!Last edited by zcenterb; 07-29-2014, 10:56 AM.CENTERBAR MOTORSPORT - Check out my small Bimmer/Beamer parts and custom projects business!
Instagram: @centerbarmotorsport
Facebook: https://www.facebook.com/centerbarmo...?ref=bookmarks
The Fleet:
-1984 325ei Lapis
-1991 325ix Diamond
- 2005 X5 4.4i Black Sapphire
-1972 2002tii Fjord - SOLD 7/8/17
-1991 325i S50 ///Sterling Silver/// - SOLD 9/15/17
The Bike:
-1980 R100RS Inca
Wow, looks bad ass! Where did you get that bent silicone pipe before the AFM at? And what filter?84 325e Burgundrot S52 M Tech 1.
http://www.r3vlimited.com/board/showthread.php?t=250109
Originally posted by Aviator View PostWow, looks bad ass! Where did you get that bent silicone pipe before the AFM at? And what filter?CENTERBAR MOTORSPORT - Check out my small Bimmer/Beamer parts and custom projects business!
The Fleet:
-1984 325ei Lapis
-1991 325ix Diamond
The Bike:
-1980 R100RS Inca
Originally posted by zcenterb View PostHigh performance silicone. http://www.hps-siliconehoses.com. its the 3.5inch 45 degree angle tube. Had to cut it down so it would fit behind my light.
Yea, only place I could find that had the 45 degree 3.5 inch tube. Only thing I didn't like was that they didn't put the receipt or invoice in the box, but not a big deal. Love it so far. Sound great tooCENTERBAR MOTORSPORT - Check out my small Bimmer/Beamer parts and custom projects business!
The Fleet:
-1984 325ei Lapis
-1991 325ix Diamond
The Bike:
-1980 R100RS Inca
Trying to get my small turned large project completed in time to enjoy it a little before winter. Luckily this will also be a winter beater (body) with snow tires and a refreshed 2.93LSD.
Drivers Side UUC Camber plate. Questionable wiring to be dealt with.
New everything up front. Catch can to be added to crankcase vent hose.
Condor motor mount and inner control arm nut to 61ft/lbs
Max neg setting
19mm front sway and IE adjustable end link
New Lem control arm with all new HDWE
IE front sway reinforcement and ECS brake line
Pass side UUC camber plate with E Bay headers
New valve cover gasket and trim pieces
Raw Magnesium valve cover with Gibbs Brand protection
Pass side max neg camber
Pass side view
M42 rad back in
New tensioner, T stat housing, T stat, Stewart pump, VANOS oil line, belt, all HDWE
New drivers side Bilstein Sports and Eibach Pro Kits
New pass side Bilstein Sports and Eibach Kits
M diff cover with Condor bushing, new fill plug and magnetic drain plug
All new except alt
600 Q Tips later
Wimpy wimpy wimpy, hefty hefty hefty!
1. Engine
S52B32: full conversion over to OBDI (includes coils, fuel rail, manifold, throttle body, etc). I had the water pipe on the side of the head tapped for the cluster temp sensor.
Stock s52 cams (intake/exhaust)
Custom intake seat and intake valve job for increased flow
24lb injectors
3" stock MAF
K&N 9in filter
e34 oil pan with stock baffle
2. Engine Wiring
S50 harness
Re-wired the c101 connector to match the harness (I chose this method because the x20 has more locations for connectors if I need one day).
Also, re-wired the harness for the cluster temp and the ecu temp sensor.
3. Drivetrain
ZF 32x (Cant remember the exact number...its the typical ZF from the e36 m3).
Stock m3 flywheel
Stock m3 pressure plate and clutch disc
E36 m3 clutch slave cylinder
E30 325i clutch master cylinder
E30 UUC Stainless Steel Clutch hose
Stock m20 transmission mount
Manual e30 driveshaft with E30 CSB (Large guibo drive shaft)
3.73 LSD (For now)
Stock ZF shifter and selector rod
E30 leather shift knob
5. Motor Mounts
E28 Green Heavy Duty motor mounts
E30 booster (Shifted over 1/2 in with a modified clevis)
E30 master cylinder with stock reservoir
Shaved the last 3 intake manifold fins off for a little extra clearance.
E10 booster check valve
7. Steering System
Stock e30 steering rack
8. Cooling System
M20 radiator
Normal M20 spider hose.
Dual 10in puller fans wired up to the e36 ti 80/88 lower temp switch (Temp gauge should run directly in the middle)
Normal Aux Pusher fan in front (Mostly for AC...but also for a backup).
9. Exhaust System
Stock OBDII exhaust manifolds (O2 sensor bungs plugged and EGR holes welded) into stock m20 exhaust.
M20 exhaust was cut in the front and mated up to the manifolds.
I had a bung welded onto the custom piece, but you can probably use one of the stock bungs and only plug the other one.Last edited by sweet3; 09-28-2014, 09:05 PM.
Here's my 1988 325i convertible.
1. Engine
OBD1 converted M52B28 from a 1998 328is, M50 intake manifold, throttle body, and fuel rail, e34 525i oil pan, oil pick up and dipstick, e36 m3 euro 3.5" 806 MAF, RK-Tunes performance chip
2. Engine Wiring
e34 525i OBD1 vanos wire harness, red-label 413 dme
3. Drivetrain
ZF320 (also from the 1998 328is) with a Sachs OEM clutch, e36 m3 driveshaft, 3.73 LSD
z3 1.9 short shifter
5. Motor Mounts
AKG Polyurethane M5x/S5x Motor Mounts
E21 brake booster, OEM E30 master cylinder and fluid reservoir
7. Steering System
z3 steering rack
8. Cooling System
OEM M42 radiator with a 16" SPAL pusher fan
9. Exhaust System
Supersprint replica (ebay) headers into a 2.5" single exhaust, Vibrant 1141 resonator, and a Magnaflow 14815 muffler
10. Cosmetics
Shaved and resprayed engine bay, battery relocated to the trunk, and e30 m3 wire harness firewall cover.
Swap completed by AMS Autowerks in Linden, NJ.
1987 325 Sedan
Engine: M50TUB25 that was very well taken care of, ~100k, ECS overdrive water pump pulley, pink top injectors, Miller WAR chip, soon to have S50 cams, no AC, no PS
Drivetrain: Getrag g250, 2.93LSD
Shifter/Linkage: AKG stage II tunnel mount short shifter, custom linkage
Mounts: Condor motor mounts, AKG cupped trans mounts
Cooling System: 318IS radiator, low temp fan switch, aftermarket fan, low temp t-stat.
Exhaust: Raceland shorty header, 2.5" piping, 12" Vibrant resonator, Vibrant Streetpower muffler
Cosmetics: Valve cover and oil filter housing powdercoated wrinkle black
IMG_20141130_163138 by Greg-Kline, on Flickr
Originally posted by thate30chick View Posti'm sorry to bother everyone on here but i'm new and i don't know how to post anything. D: i just have a question to ask~~~
