Any concensus here on whether to stay with studs on the outlet side of OBD2 manifolds, or pop them out and expect to place nuts and bolts? I have the engine on a stand right now with one or two bad studs. I figured I can replace the bad ones now, or remove them all, depending on advice received. Just a whole lot easier now either way. I thought I read in one of these topics that somebody had a tough time getting the lower section to bolt up to the OBD2 header with studs in it once in the car. Anybody else find that to be the case? I plan to use the front pieces cut off a late e36 midsection to bolt to manifolds, then an aftermarket 2-1 Y pipe to join in to my existing 2.5" single. Strictly track car.
Thoughts?
Thanks!
Ken
Thoughts?
Thanks!
Ken
