s52 fires but won't stay alive
  • dmjensen
    • Jan 2011
    • 805
    #31
    Thats a good question.. is the sensor for the gauge in the head or the radiator?
    If its the one in the head, its the oe one from the e36. If its the one in the rad, i replaced it with a two prong because i thought that was the aux fan switch
    • 328ijunkie
      • May 2007
      • 3961
      #32
      Well theres your problem. You need the E30 sensor in the head for the temp gauge to work.
      Check Us out on Facebook
      Full Product Line Tuning
      • dmjensen
        • Jan 2011
        • 805
        #33
        Lol. Alot of this stuff wasn't mentioned to me before. Will that be the same size as the e36 because im not drilling anything into that head.
        • 328ijunkie
          • May 2007
          • 3961
          #34
          Shameless plug:
          The page you're looking for does not exist. Please visit our home page or locations page for more information.
          • gmyatko
            • Nov 2012
            • 1
            #35
            S52 motor turns over momentarily fires up, won't stay lit unless I put my foot in it
            Hi, I just read someones post, not sure it applies to me. We were tracking our '97 E36 M3, and spun into the dirt, kicking up a lot of stones and dust. Right before the spin, the car ran fine. After the spin, the car wouldn't stay fired up more than a 1/2 second. It continually does this. If I put the pedal all the way down, it will sort of stay fired up, but there's an obvious problem so I didn't want to keep it fired up that way for any reason. I checked the fuel rail pressure = ~ 52PSI steady. I found the PCV valve cracked open on the back, and the big red rubber diaphragm inside was exposed with a big tear, so we thought we found it due to a huge vacuum leak. Replaced it, had same issue.
            So we're going to try someones suggestion of unplugging the MAF then the tps then both and see what it yields. In the meantime, if this sounds somehow familiar to anyone, I'll be checking back.
            Thanks
