s52 fires but won't stay alive
  • dmjensen
    • Jan 2011
    • 805
    Idle control had poped out of the intake lol.
    Still wont run on its own though, im thinking its because i have no exhaust or back pressure at the moment
    • DesertBMW
      • Aug 2011
      • 1043
      it should run just fine with headers only
      • BBDirtbiking
        • Apr 2012
        • 323
        My car ran fine with no O2 sensor or exhaust.
        What were the results from the tests I mentioned. (unplugging sensors and what-not)
        "Bayerische Motoren Werke - freude am fahren."
        Brandon {Current: 1991 318iS, 2007 328i, 2014 X5 xDrive35d | Past: 1992 525i, 1997 528i, 1999 540i}
        • dmjensen
          • Jan 2011
          • 805
          I have yet to unplug any sensors since the icv was completley seperated from the intake. Im going to finish my exhaust tomorrow and then investigate further. Anyone have a picture of the under side of an ovd2 manifold handy? ( i think i have all my vac lines but i just want to be certain )
          • 328ijunkie
            • May 2007
            • 3961
            3 vac lines, ICV and CCV.
            Check Us out on Facebook
            Full Product Line Tuning
            • dmjensen
              • Jan 2011
              • 805
              Okay ive got all 3 then. One to the fpr, one to the charcoal canister valve, and one to what ever diapram thing is connected to the fuel rail. Sooo my next thing will be to clean my icv
              • 328ijunkie
                • May 2007
                • 3961
                What? Thats the FPR....?
                • dmjensen
                  • Jan 2011
                  • 805
                  Fpr is in the little box of things under the drivers seat on the e36's. The thing im talking about has a vac hose going over to what use to be the secondary air line.
                  • 328ijunkie
                    • May 2007
                    • 3961
                    ah the solenoid valve.
                    • dmjensen
                      • Jan 2011
                      • 805
                      so it runs, if i keep my foot on the brake...
                      massive brake booster leak, sooo looks like i'll be running no power brakes for awhile :up:
                      • 328ijunkie
                        • May 2007
                        • 3961
                        Gasket between MC/Booster there?
                        • dmjensen
                          • Jan 2011
                          • 805
                          You can hear the vacuum leak from the inside of the car but not the outside.
                          • 328ijunkie
                            • May 2007
                            • 3961
                            Dead booster :(
                            • dmjensen
                              • Jan 2011
                              • 805
                              I know... Any reason why my temp gauge dosnt work? When you turn the key the needle wiggles up to right before the blue but then after about 5 minutes of running it wont budge. Id really like that to function haha
                              • 328ijunkie
                                • May 2007
                                • 3961
                                what temp sensor are you running?
