Ob1 24v swap harness misery wire?
  • Classicoe30
    • Apr 2012
    • 205
    Any one knows where and what this wire does in the ob1 harness is a black&green wire it comes with the harness! Can some tell if a signal wire or where it should be connected thanks in advance!
  • nrubenstein
    • 3148
    Download the ETM from wedophones.com and have fun.
    2002 BMW M3 Alpinweiß/Black
    1999 323i GTS2 Alpinweiß
    1995 M3 Dakargelb/Black
    - S50B32/S6S420G/3.91
    1990 325is Brilliantrot/Tan
    1989 M3 Alpinweiß/Black
    • Classicoe30
      • Apr 2012
      • 205
      Ok sounds like I'll have lots fun!
      • Farbin Kaiber
        Lil' Puppet
        • 29502
        Picture?
        Is it anywhere near the wires that go to the starter?
        • Classicoe30
          • Apr 2012
          • 205
          Yes it is near the starter! So is it a signal wire?
          • Mossman
            • Apr 2006
            • 1961
            If it's just a bare wire I'm 99% certain it's the wire to your starter to tell it to spin. Should have a ring wiring connector on it but it could have been cut or something. Can't remember if it's the 8mm or 10mm nut on the starter, thinking the 10 though.
            • Classicoe30
              • Apr 2012
              • 205
              Yes it is something like that! Thank you I'll check it out!
              • evoDRichie
                • Jan 2010
                • 1743
                he is correct starter wire...
