s52 obd1 probs
  • evoDRichie
    • Jan 2010
    • 1743
    s52 obd1 probs
    ok so it cranks of coarse but no fuel comes out and no spark...
    power is going to the injectors and fuel pump yet neither are working
    no CEL, ive checked all the grounds multi times, chip is not in backwards and spare unchipped 413 is not turning it over either...
    any advice?
  • BBDirtbiking
    • Apr 2012
    • 323
    Originally posted by evoDRichie
    Chip is not in backwards.
    Ruled out what I was going to say... As I did that with my car.
    If you don't have spark then it may be a relay... If you had everything but fuel, I'd say the lines were backwards.
    "Bayerische Motoren Werke - freude am fahren."
    Brandon {Current: 1991 318iS, 2007 328i, 2014 X5 xDrive35d | Past: 1992 525i, 1997 528i, 1999 540i}
    • evoDRichie
      • Jan 2010
      • 1743
      lines are off when cranking no fuel comes out ... after testing my whole wiring harness with a multimeter i have come to the conclusion that my crank sensor or cam sensor may be bad... the crank sensor has .39 and i cant get a reading on my cam sensor... how much resistance should they have if any, anyone know? .. also would this cause no fuel /spark, if one of those sensors were bad?
      • FredK
        • 14763
        Yes. If the crank sensor is bad, there won't be any fuel or spark. The crank position sensor should ohm out at around 540 ohms.
        • evoDRichie
          • Jan 2010
          • 1743
          well then i believe it is bad
          • evoDRichie
            • Jan 2010
            • 1743
            Will the bad crank sensor cause no CEL?
            • 328ijunkie
              • May 2007
              • 3961
              ^sometimes yes. And all the motor needs to ATTEMPT to start (I.E. Fire spark/fuel) is crank signal. you could have EVERY other sensor unplugged and it would still start.
              Check Us out on Facebook
              Full Product Line Tuning
              • samiam3356
                • Jul 2009
                • 1901
                Have jumped the fuel pump just to make sure there are no issues there?
                Originally posted by Roysneon
                $5 shipped?
                Originally posted by MarkD
                You are a strange dude, I'n not answering any more posts from you.
                • evoDRichie
                  • Jan 2010
                  • 1743
                  have not planned on doing that today...
                  • jrdeamicis
                    • Nov 2008
                    • 956
                    if you dont have a Cel you either
                    Wired C101 wrong
                    or
                    The ECU is dead
                    or
                    The CEL lamp is out.
                    GO!
                    Past Car : E30 S50 6 Speed 5 Lug 3.73
                    Current : Z3 S50 OBD2 (Smog Legal) 6 Speed BBS RN Dual Ear Diff
                    ___________________________________________
                    BNB Designs
                    Engine Swaps, Fabrication, Innovation, General Repair
                    Richmond CA
                    Julian 848-248-8029
                    • evoDRichie
                      • Jan 2010
                      • 1743
                      she lives! CPS was bad... and i guess my bulb for my CEL is just burnt out
