Getrag 250 vs ZF trans ratios
    How much different (if at all) are the ratios between a ZF and a G250? I'm running a Getrag right now but may want to upgrade to the stronger/newer unit later and don't want to have to change the rear diff to compensate at the time.
    Also, would I need a different driveshaft? Using the E36 325is part that matches the G250.
    Originally posted by mbonanni
    I am a pursit now.
    Barley different at all. Were talking like .05 difference in some gears.
    You would need a ZF DS.
    Check Us out on Facebook
    Full Product Line Tuning
      (Ninja Edit)
      I win:
        You could not use the ETA driveshaft? Need to source either one really.
        _________
        Rep Savannah Crew
          You can
