Hi all i have a question about wiring my s52 swap. I am only checking if im right.  I have researched everything i could web, forums and ETM's. this is what i came up with. i have a 91 325.
C101 X20
pin1 alt blue pin 25
pin2 oil static N/A
pin3 N/A N/A
pin4 CTS br/wht pin 12
pin5 oil pressure brn/grn pin 23
pin6 N/A N/A
pin7 ignition grn pin 21
pin8 yl/wht pin 24
pin9 Black pin 20
pin10 oil dynamic blu/wht N/A
pin11 diag wht/grn pin 22 or 19 not sure
pin12 check grey pin 8
pin13 fuel grn/vio pin13
pin14 speed blu/ylw pin14
pin15 start blk/ylw pin15
pin16 diag wht/blk pin 17
pin17 N/A N/A
pin18 start blk/ylw pin18
pin19 N/A N/A
pin20 ABS red/wh
for the ABS i gathered that you connect the pin20 to the pin6 on the c101 im not sure about this and need some clarificaion.
for oil level i wire pin10 and 2 on the c101 to the sensor on the pan
if anyone can help it would be great.
thanks,
Alex
					C101 X20
pin2 oil static N/A
pin3 N/A N/A
pin6 N/A N/A
pin8 yl/wht pin 24
pin9 Black pin 20
pin17 N/A N/A
pin19 N/A N/A
pin20 ABS red/wh
thanks,
Alex
