So I pulled the vaccum hose from the booster and from the manifold and have been running without brake assist and did another stomp test and Got 1224?
No power towards uptop
Status: HG repair. 488wtq though!Comment
Check the code and it's engine air temperature sensor which I checked.....isnt hooked upside I will get back with you guysComment
Hooked up the sensor and reset it and the CEL went away but it still hesitating/sluggish when floored on acceleration. So
I'm guna circle back to the VSS problem. Im pretty sure I wired it correctly...I thinkComment
So what I'm looking at is that I have to run a wire from the C104 under the glove box to the e36 pins #20?
Correct?Comment
I sent my VSS signal straight from the C104 to pin 42 on the ECU (red 413)'87 325ic, powered by S50.Comment
