No power towards uptop
    I have a CEL, when accelerating I have some power/torque but when I get past 5 it's just a flat climb and that's with the pedal floored. And if I beat the crap out of it (floored everywhere I go) the CEL will disappear then the car will start to pull normal instead of sluggish.
    94 M50b25TU in a e30. My guess is maybe a bad IAVC, which I could just remove
    Because V8
    http://www.r3vlimited.com/board/showthread.php?t=282219
    Doing it wrong since 91:wgaf:
    caaaan you get the code? It's probably pinging.
      What's pinging?(knocking?) And another note is that when I hook it up to the scanner I always get knock sensor circuit 1&2 and vehicle speed sensor.
      But when I do the stomp test I get code 1221 which is a massive vaccum leak correct?
      Because V8
        pinging is knocking yes. May want to get new knock sensors. I forget what speed sensor means... wiring isn't right or something.
        1221 basically means the car is running like ass. Not necessarily vacuum leak. But that's a good place to start.
          Ok took the intake off and one of my knock sensors was basically falling apart so I replaced it and put everything together and it ran a little better but still a little sluggish up top. Then the CEL came back on. Waited till I got home and did a stomp test and got 1222?
          Because V8
            THAT is usually a vacuum leak.
              Check your fuel supply too. That happened to me and i found out my fuel filter was clogged.
                knock sensors + VSS = no top end.
                Check Us out on Facebook
                Full Product Line Tuning
                  My fuel filter is new. And with the vaccum leak would a hissing booster cause a massive leak? And the VSS, I wired it to my c101 from the e36's X20 the blk/wht to the blk/wht
                  Because V8
                    a hissing booster IS a massive leak.....
                    '87 325ic, powered by S50.
                      Okay well removing that vacuum line from the engine and just running manual brakes for awhile will remove the leak from the motor correct?
                      Because V8
                        Youve found your problem. And yes but good luck with no power assist, esp if youre running an oversize master cyl. Start getting your legs roided up lol
                          Lol I'm pumping the steroids as we speak! Lol
                          Because V8
                            Yeah running a stock system with no vacuum assist is a bad bad idea and I really hope you're not doing that on the street with other drivers around.
                            That being said, as per the VSS issue, my car didn't run right at all until I fixed the speed sensor up. Did your speedo work before the swap?
                            Originally posted by mbonanni
                            I am a pursit now.
                              Yes my speedo worked before and I have a early model (1990) and its only temporily till I fix my current booster
                              Because V8
