Let's talk cooling fans.
  • dude8383
    • Jan 2005
    • 10387
    #31
    Originally posted by nrubenstein
    That was not a euro fan pictured above. At least not the same as I have.
    Thats exactly what we run but I'll confirm with you tomorrow.
    • Danny
      • 14216
      #32
      Originally posted by blackhawkimpact
      Yes
      Part number or model/year?
      • blackhawkimpact
        • 2415
        #33
        Audi A4 97-2005. You can buy OEM or buy it from this guy that I bought it from. $17 shipped and it works well.
        http://www.ebay.com/itm/New-Fan-Blad...orcev4exp=true
        • 5Toes
          • 9836
          #34
          how much clearance does that give?
          what radiator you guys using?
          • evandael
            • Oct 2009
            • 2881
            #35
            what fan clutch do you run that with? OEM BMW?
            • nrubenstein
              • 3148
              #36
              Nice! That's cheap and probably quieter. And probably designed to turn at higher revs.
              2002 BMW M3 Alpinweiß/Black
              1999 323i GTS2 Alpinweiß
              1995 M3 Dakargelb/Black
              - S50B32/S6S420G/3.91
              1990 325is Brilliantrot/Tan
              1989 M3 Alpinweiß/Black
              • dude8383
                • Jan 2005
                • 10387
                #37
                I just double checked and that is exactly what we ordered... so you must have some other euro fan then :)
                • blackhawkimpact
                  • 2415
                  #38
                  Not sure which e30 clutch fan I have but it's the one with the four bolts not three. The one with three doesn't work because the clutch fan is bigger and it won't fit through the hole. I believe it's an m42 clutch fan though. But yes the clutch fan is OEM BMW not the fan though.
                  M42 radiator
                  • dude8383
                    • Jan 2005
                    • 10387
                    #39
                    Originally posted by travish325
                    why the fuck.
                    *edit* i'd like to thank whichever mod removed the link travish posted. motion to BAN.
                    • ZekeTheSneak
                      • 1562
                      #40
                      I haz spal pusher wired to my stock electric a/c plug. Press the snowflake and presto instant cooldown.
                      • cmybimmer
                        • 894
                        #41
                        M42 radiator
                        Would the e30 clutch + audi fan combo clear the m20 rad? Im not running a fan atm, and I still have my e30 fan clutch, so if it would clear the m20 rad i'd go that route asap.
                        This is how much clearance I have, enough?
                        Last thing I want is my fan to blow up in the rad..
                        • blackhawkimpact
                          • 2415
                          #42
                          I believe the m20 radiator is thinner than the m42 radiator. So it should fit. Regardless, looks like you have plenty of room there, I bit more room than I do. It should work.
                          • cmybimmer
                            • 894
                            #43
                            schweeeet.. Ordering now :up:
                            • FreedS4
                              • 752
                              #44
                              Thread revive here, but for your guys running the 16" SPAL as a pusher, are you running A/C as well? Thanks!
                              Chris
                              • SwiftE30
                                • Jun 2010
                                • 998
                                #45
                                iI completely eliminated my AC and running 16 spal pusher. works great. In the Seattle area AC is just a luxury and since my e30 is a vert is already has built in AC, the cool seatle air.
                                1989 E30 Zinnoberrot Vert 325i OBD1 S52 turbo;IP
