I just got the head redone, and also installed a new fan clutch, thermostat, and water pump. It's still getting super hot. Any ideas what it could be?
e30 s50 swap over heating
Tags: None
I know this is a basic question, but always a great place to start...are you sure there are no air bubbles in the cooling system? With all those items replaced it's quite possible there is air in the system.Originally posted by blunttechAlways Always go for the reach around if there is an option -
You need to get the front of the car jacked up, or park facing up a hill. Use the small hose that goes from the radiator to the reservoir as a bleed valve. Start the car, rev it up a bit and wait for it to start warming up. You should have the heater turned up to full hot, and the fan on all the way. As it gets hot, pull the small hose back a bit of the radiator. You will probably see bubbles. Keep doing this until you have coolant without bubbles coming out.
What temp thermostat did you use?‘Tis by the grace of God that my cars run!Originally posted by LJ851kingston is the play by play announcer for this thread.
Siobhan's Build Thread - UPDATED!Originally posted by unloadedak#teamross
using an M42 radiator? I have one and its a pain in the ass to bleed. Use the top hose method to fill it up.'87 325ic, powered by S50.Comment
what temp sensor are you using?sigpic
Levent
%20levent@gutenparts.com
Ladies:
1998 E36 m3/4/5 1988 325i 1989 325iTComment
i just took it to a shop and they said it could be the water pump but its new or the thermostat but its new i bought it from them. they said im not getting go flow because the top hose is hot but the bottom is cold even when at running temp so what could it beComment
Hot top and cold bottom suggests that you have either a bad radiator or a bad water pump. A bad thermostat would mean a cold top hose.2006 GMC Sierra 2500HD 4WD LBZ/Allison
2002 BMW M3 Alpinweiß/Black
1999 323i GTS2 Alpinweiß
1995 M3 Dakargelb/Black - S50B32/S6S420G/3.91
1990 325is Brilliantrot/Tan
1989 M3 Alpinweiß/Black
sigpicComment
i took out thermostat becasue it wouldnt open but its still getting hot i bypass the heater core becasue it was leaking but water goes through the radiator and the water pump is new and my fan clutch wont turn on. could it be my radiator because its not getting go flow because the fan clutch is new tooComment
