Build rule #5) Don't discount stuff because it's new.
e30 s50 swap over heating
Was the head tested / machined when you did the hg?
Is the radiator new? or has it been tested? Do you have rust in the system?Last edited by Jean; 09-12-2012, 10:48 AM.Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
OEM v8 manual chip or dme - https://www.r3vlimited.com/board/sho....php?p=4938827Comment
Did you replace the head fastener bolts with new?OBD1 M54/M52TU swap as a M50b25
yeah found out my fan clutch ever turns on ether so imgoing to but a electric fan and see if that works. i had it at the shop before they resurfacedComment
my s50 started overheating for little bitt, because my ground straps were loose, tightened them and perfectly middle with the e30 fan..
1988 325is S50 in-progress.
http://www.facebook.com/E30LocalCrew
Few pictures:
http://www.r3vlimited.com/board/showthread.php?t=255061Comment
car is running great with a e fan and ever time i turn on the heater my temp alway seem to move up and get hotterComment
Did you ever get the flow of the system fixed? I’m sure doing the E-fan would allow it to run cooler but if you’re not getting proper flow I can only assume that there will be issues.The greatest honor an e36 could ever have... to be parted out and have its parts used in an e30.
The difference between a porcupine and BMW’s. BMW’s have the pricks inside.Comment
