Misfire on Cylinder 5
  • Slovik
    • Jan 2010
    • 198
    The car is a 91 318is S52 OBD2, I got on the car hard yesterday in 1st gear up through 2nd and got a misfire and check engine light. Limped the car home and hooked up the reader and got PO305 (misfire Cylinder 5) and no other codes. Pulled the coil off of 5 and switched it for known good one I had laying around. Turned the back on and it runs perfect, figure I'm a genius. Today I run it hard up through the gears and get the same misfire, cylinder 5. This time I swap plugs and coils from 5 to 4. Start it up runs fine. Run it hard through the gears again and get cylinder 5 misfire. If I just shut the car off and restart it the misfire goes away every time. Seems obvious that it is a fault with wiring on cylinder 5 but where should I start, do the coil connectors go bad? Why would the car reset itself after a shut off each time. The car has run perfect for almost 5 months since the swap and nothing recently has changed. Any thoughts would be greatly appreciated.
  • 328ijunkie
    • May 2007
    • 3961
    Check compression :/
    Check Us out on Facebook
    Full Product Line Tuning
    • Slovik
      • Jan 2010
      • 198
      Thanks Junkie I'll do that tomorrow but I really feel like it is electrical as the car misfires until you turn it off and then it is fine on restart and runs perfect. If I don't blast out of the hole, I can rev it to 6k or so with out it happening.
      • DesertBMW
        • Aug 2011
        • 1033
        Where did you get your OBD2 ecu tuned?
        http://www.r3vlimited.com/board/showthread.php?t=261153
        • 328ijunkie
          • May 2007
          • 3961
          ^didnt see that coming. Oh wait. I did.
          Your ecu is smart. It sees something wrong and it shuts down that Cyl till either it feels it's safe to restart or until you restart the car..
          • Slovik
            • Jan 2010
            • 198
            The ECU wasn't tuned so to speak, I had TRM leave all parameters stock just delete the rear O2 sensors, EWS and Raise the idle a bit as I run a light flywheel. It has been running fine for 5 months so the "tune" is pretty unlikely issue. I did go back and read that post though, I wonder if I could have a bad injector, how would one test for that?
            • 328ijunkie
              • May 2007
              • 3961
              Eat a shoe DesertBMW. :P
              try swapping an injector. Sometimes they can intermittently stick.
              • Slovik
                • Jan 2010
                • 198
                Makes Sense!! Thanks Junkie
                • DesertBMW
                  • Aug 2011
                  • 1033
                  Tune is the most likely issue if you changed the coil, spark plug, I had a coil melt on cylinder number 5 with TRM tune, they do some tuning to coil dwell time and that resulting coil driver gets too hot stops working or simply shorts itself
                  • 328ijunkie
                    • May 2007
                    • 3961
                    So basically everyone tuning OBD2 ruins everything except you? TRM is Technica's direct competitor and ive honestly got nothing bad to say about them/their tunes.
                    Again, swap the injector and check compression. I hardly ever see wiring harness issues, and have never really seen a tune cause 1 specific cylinder to continually shutdown.
                    • Slovik
                      • Jan 2010
                      • 198
                      Found the problem this morning, Put the reader back on it and got a second code P0205 (open circuit #5 injector) it is the injector connector. One of the contacts is pushed back into connector. I no doubt did this when I was experimenting with some yellow tops a few weeks ago. Problem is how do I correct this, is there a way to replace that connector?
                      • Slovik
                        • Jan 2010
                        • 198
                        Maybe this? https://www.autohausaz.com/search/pr...98&cid=22@Fuel %26 Air System&gid=11222@Fuel Injector Repair Kit
                        Part number 1287013003 if that link doesn't work
                        • Boosted E30
                          • Dec 2009
                          • 288
                          Just open up the plastic cover that contains the injector harness and push the wire back into the connector.
                          • 328ijunkie
                            • May 2007
                            • 3961
                            wow. Beauties of OBD2 :D
                            +1 Open injector harness box and you should be able to snap pin back into its slot. If not you can buy a replacement pin, crimp and reinstall.
                            • Slovik
                              • Jan 2010
                              • 198
                              Fixed, Took 2 minutes. Thanks Junkie, Boosted and Desert, This is exactly why I wanted to go OBD2 in the first place!
