Misfire on Cylinder 5
  • DesertBMW
    • Aug 2011
    • 1042
    Originally posted by Slovik
    Found the problem it is the injector connector. One of the contacts is pushed back into connector. I no doubt did this when I was experimenting with some yellow tops a few weeks ago.
    So you did not have any problems prior to experimenting with other injectors, then after that you started having problems, but then you fail to disclose that and fool all of us here trying to guess what your problem is, you all along knew where the problem was, injector will simply not lose connection on its own you had to mess with it and you knew that
    • Slovik
      • Jan 2010
      • 198
      Nope car didn't run bad until 3 weeks after injector change just didn't think of it at the time, must have shifted the contact just the slight bit over time, rough roads engine vibration and a few violent shifts into 2nd. Didn't think of the connector until the diagnostic gave me PO205 this morning. You have a very suspicious mind, not sure why.
      • 328ijunkie
        • May 2007
        • 3961
        ^Hes angry it wasnt the tune. :P
        Check Us out on Facebook
        Full Product Line Tuning
