Clutch Pedal dropping to floor occasionally - S52 with Getrag 260
  • Rich@GTBPerformance
    • Jul 2011
    • 160
    Hey guys
    Having a problem that is puzzling me. My clutch pedal drops to the floor occasionally. Happens while driving, and while stopped. Overall it has happened about 6 times since Kylie has been on the road.
    Not sure what could be causing the issue. The lines have been bled several times and we don't think it is an air bubble. Clutch pedal feel is solid, not sqishy.
    The pedal can be brought back up to the top, and once it is brought back the pedal feel is solid again. Clutch is not slipping in any gear.
    We are using the original 325i master cylinder with IX brake booster.
    Does anyone have any thoughts?
  • dude8383
    • Jan 2005
    • 10387
    Brakes feel fine right? I remember you had mentioned it when we talked at Bimmerstock.
    I don't recall if you said the slave was replaced... or original?
    • GunMetalGrey
      • Dec 2010
      • 1499
      I am not one hundred percent on this but doesn't that happen when a master goes bad?
      • blackhawkimpact
        • 2415
        Had the exact same problem. Changed my slave cylinder and everything works great now.
        • 328ijunkie
          • May 2007
          • 3961
          Slave Cyl Most likely. MC is next in the subject lineup. Basically one of the two is bleeding down pressure. You pull the pedal up and it repressurizes until it leaks down again.
          Check Us out on Facebook
          Full Product Line Tuning
            • Jul 2011
            • 160
            Didn't replace it yet, no.
            Neat! Thanks!
            I'll probably have both replaced just to avoid running into any issues with my hydraulics. With an S52... I certainly need the brakes now more than ever!
            • nrubenstein
              • 3148
              Replace the clutch hard line, too. That was my problem, and it's better while you're in there.
              2002 BMW M3 Alpinweiß/Black
              1999 323i GTS2 Alpinweiß
              1995 M3 Dakargelb/Black
              - S50B32/S6S420G/3.91
              1990 325is Brilliantrot/Tan
              1989 M3 Alpinweiß/Black
              • FLG
                • Sep 2011
                • 3165
                Replace all the clutch hydraulics...usually when one goes the other isn't far off.
                Sent from my Galaxy Nexus using Tapatalk 2
                -Build http://www.r3vlimited.com/board/showthread.php?t=295277
                • Bimmerguy91
                  • Jul 2012
                  • 982
                  This. Replace both the slave and master. Usually when one fails the other will follow suite.
                  • Jand3rson
                    • 37587
                    Get the steel-braided one from Blunttech. Well worth it.
                      • Jul 2011
                      • 160
                      Good suggestion!
                      • nrubenstein
                        • 3148
                        HARD line. Not the rubber line. The pipe itself. It's pretty easy to replace when you are doing the master, and really annoying otherwise.
