m50 relay the white one
    wont stop buzzing like crazy. its buzing like crazy and vibrating. more than it should.
    i was trying to jump start my m50 car and the posi jumper cable touched the ecu.
    do you think i fried my ecu?
    idk why its not working. i tried a different white relay and it did the same thing.
    the white relay controls the fuel injection and im not getting any fuel.
    eeek. Never had that happen but i dont see it going well for the ECU....
    Check Us out on Facebook
    Full Product Line Tuning
      ya. idk what happened. its also not pumping fuel. it does and then doenst. its was hooked up fine before and it ran fine. but now it doenst pump fuel. and i know that, that the white realy controls the injectors. but idk why it inst pumping
        can you bypass the relay?
        sigpicFellow e30 enthusiast
        Dont waste your time hating, aint nobody got time fo dat
        1986 bronzit 325es- SOLD
        1987 delphin 325i- parts car
        1990 scwarz 325is- m50 drift slut
        CHECK OUT THE BUILD!
        http://www.r3vlimited.com/board/showthread.php?t=229234
          up, idk what it is. i just changed all the relays.
          what could cause this!!!
            the fuel pump isnt priming either and its a early model
              up up up come one help me out. could it be the ecu?
                Could be. When you switch on IGN it powers the relay which sends power to numerous things, the fuel pump relay included. I jumped it initially when I had a no start on my second swap. It was the problem. I'm not sure why it's buzzing though. That means it is being turned on and off super fast basically. DME could be pooped.
                  ya i think the DME is sending it incorrect power or something. i need a dme to test it though QQ need to go buy one nwo
