Secondary Air Pump Simulator
  • Slovik
    • Jan 2010
    • 198
    Is anyone using a secondary air pump simulator to keep their OBDII swap from giving a check engine for SAP. I get P1421 and P1423 and it looks like a simulator will get rid of the code. Also have slight uneven running for the first minute or two on cold start up and thought this whole SAP may be the issue.
    http://www.ebay.com/itm/BMW-Secondar...c5425e&vxp=mtr
    http://www.ebay.com/itm/BMW-Secondar...578f7c&vxp=mtr
    Would appreciate any thoughts on this.
  • DesertBMW
    • Aug 2011
    • 1040
    That is not because of no SAP, that is normal. Later BMW issued another flash to fix that cold idle hesitation. I got those new programs.
    why would you spend money on simulator and have to cut wires, when you can just get your DME properly flashed, and will look all factory and no need to do anything else
    • Slovik
      • Jan 2010
      • 198
      Just what I wanted to hear! I didn't want to spend money on something that just covers up the problem. Can you flash out the SAP also while you are at it and how much to do it?
      • DesertBMW
        • Aug 2011
        • 1040
        yes. cheap, PM me
        • Slovik
          • Jan 2010
          • 198
          Sent
          • Slovik
            • Jan 2010
            • 198
            Wow Desert that new ECU worked great!!! Dead cold start w/perfect drivability no SAP light yet and the power through my butt dyno feels better too. Was that a pure stock BMW tune or is it pumped up a bit. Feels great, I'll need some rear tires soon I'll bet.
            Thank You
            Seth
            • DesertBMW
              • Aug 2011
              • 1040
              Thank You
              Seth
              glad to hear that, you did doubt me at first but now you are a believer.
              • Slovik
                • Jan 2010
                • 198
                I am!!
