the G250 and it was close to the top of 4th with the 3.73 lsd.if you look at my other videos all my mods are listed but it was tunned at miller performance on a dyno.
Swap 1/4 Mile Thread
Can you tell me how much power did you make ... and what cams are thouse that are stated in you're other video ? thanks allotOriginally posted by Toadleg View Postthe G250 and it was close to the top of 4th with the 3.73 lsd.if you look at my other videos all my mods are listed but it was tunned at miller performance on a dyno.
At the time i had the m42 tranny and 4th was 1:1 but they had the car tuned in 3rd so im not sure how much that changes the results....... But it was 200 whp On a unsmooth graph and 195 when smoothed out @ about 5800rpm.They are factory cams that I had a local shop called Delta do a regrind on them I can explain that more if your unfamiliar with the process.
ZF/G250 same difference. :)Originally posted by Toadleg View Postthe G250 and it was close to the top of 4th with the 3.73 lsd.if you look at my other videos all my mods are listed but it was tunned at miller performance on a dyno.
What specs did you have the cams reground to, S50? You didn't make ~200whp with an M50TU with stock cams and internals.Originally posted by Toadleg View Postreground factory cams,intake, full exhaust, G250, Lightweight flywheel, War chip on dyno tune..... Thats it for performance I think, O and no ac or cluth fan
Also, how much did the regrind run you? Just curious.paint sucks
I have a cam card I can read off to you at what lift do you want to know the duration? They are factory cams but they grind the bottom part of the cam to make them bigger. All dynos are diff. I wouldnt go off that and to judge the car the dyno could be a lot different than another you know how that can go.......
I have heard something about that... i am not familiar with the proces but if they make power for less then the m3 cams then they are worth it...Originally posted by Toadleg View PostAt the time i had the m42 tranny and 4th was 1:1 but they had the car tuned in 3rd so im not sure how much that changes the results....... But it was 200 whp On a unsmooth graph and 195 when smoothed out @ about 5800rpm.They are factory cams that I had a local shop called Delta do a regrind on them I can explain that more if your unfamiliar with the process.
So they left the lobes but ground down the base circle to add some lift and duration... alright.Originally posted by Toadleg View PostI have a cam card I can read off to you at what lift do you want to know the duration? They are factory cams but they grind the bottom part of the cam to make them bigger. All dynos are diff. I wouldnt go off that and to judge the car the dyno could be a lot different than another you know how that can go.......paint sucks
Bump!
Et: 13.6@102/ rt: .096/ 60ft: 2.132
S50/ZF 5sp/2.93lsd
Unplugged 3.5" MAF, K&N filter w/ no heat shield, underdrive pullies, eBay headers-single 2.5" w/ single in single out 2.5" magnaflow, Technica Motorsports tune, 205/55 Goodyear Eagle GTs.
My MAF is unplugged for now because there was a miscommunication on specs for the motor and the tune is for a 3" MAF so the motor freaks the @&;!:'s out and runs like "poopdick." And I'm also working on a heatshield because I know my intake temps are upwards of hell degrees.
EDIT: the swap was done by a good friend of mine. Markert Motorwerks. Does awesome work!Last edited by E30auddie; 07-28-2011, 07:35 PM.
^ftw
Check Us out on Facebook
Full Product Line Tuning
