Swap 1/4 Mile Thread
  • MacBudd541
    • Apr 2006
    • 1042
    #541
    Bump. Nobody drags their cars these days?
    1989 325i Alpine s52 coupe
    2003 540i M-Sport 6 speed
    2003 X5 3.0
    • Reichart12
      • Aug 2012
      • 2163
      #542
      I never knew about this thread. Id like to make it to the track this year for some passes, but Im 2.9L M20 anyways...
      Instagram: Reichart12
      • justin_l_
        • Jun 2007
        • 1079
        #543
        I'd like to get the OBD2 SC S52 to the track this year, but we'll see.
        • st.petebiodiesel
          • Jul 2015
          • 211
          #544
          M60 1/8 mile
          reaction: .5557
          60 foot: 2.0717
          330 foot: 5.7742
          1/8 mile: 8.7424
          1/8 mph: 83.30
          est 1/4: 13.5-13.7
          The car: 1987 325e with m60B40, dudmd chip, mustang injectors, 5 spd ZF, 3.15 torsen diff, 225/50zr16 toyo RA1 on the rear with -5 degrees of camber.
          lots of wheel hop out of the hole even after warming the tires up several runs back to back. I know the rear camber is killing me.
          hopefully with the rear camber adjusted out and some smaller diameter drag radials I could get a 8.4 - 8.5.
          • justin_l_
            • Jun 2007
            • 1079
            #545
            Back when I had my orange car it had a lot of wheel hop as well. Unless you get a proper setup, it seems to be common with these cars.
            With any luck this year I will finally be able to get the supercharged S52 down the track.
              • 34839
              #546
              as far as I understand it, wheel hop is mostly a function of shock rebound & spring rates.
              • Sam8888
                • Sep 2014
                • 4
                #547
                M20B25 in E21 body:
                60ft: 2.362
                1/8sp: 116,7
                1/8t: 9,866
                1/4sp: 149,7
                1/4t: 15,163
                Racing excuses: max ign. advance was 28 deg, crappy open diff and street tires, full interior.
                Engine specs: M20B25 with ported cyl head, headers and VEMS ems.
                I guess i could do 14s since i had the cyl head rebuilt now (it had 5 bent intake valves! ).
                • st.petebiodiesel
                  • Jul 2015
                  • 211
                  #548
                  1/8th mile 1987 325e sedan full interior, air conditioning, m30b35/G260 swap, 225/50/16 tires, Microsquirt,100 hp nitrous. I know my 60 foot needs work. Sent from my SM-G960U using Tapatalk
                  • nomansland92
                    • 1657
                    #549
                    I just started doing 1/4 miles runs with my car. My 60ft is terrible because I was spinning till 3rd. The car is a 325ix turbo with a dct. I'm hoping to run a high 10 this year. Sent from my SM-G892A using Tapatalk
                    IX being restored here
                    Ix turbo build here
                    • st.petebiodiesel
                      • Jul 2015
                      • 211
                      #550
                      Tossed some drag radials on my sedan Needless to say it helped a lot. Equates to a 12.6 sec 1/4 mile. My goal is to get this car to run a 11.50 with more nitrous and some weight reduction. Sent from my SM-G960U using Tapatalk
                      • Tomv84
                        • Jan 2014
                        • 3
                        #551
                        1987 325 with m30b35, 2750 lbs weight with driver and about half tank of gas. Ran 14.3 at 97 last week. Car is consistent and very easy to launch with the g260/3.73 diff.
