M20 to m50 Wiring questions
  • JFarhanbod
    • 2151
    Sup guys. I'm finally doing my wiring harness and when I opened the m20 harness up I found this. Looks like pin 12 is spliced to a brown wire. Wondering if this is fine and if not how do I fix it? According to rmeuropean pin 12 is the CEL. Thanks bruhs
  • JFarhanbod
    • 2151
    Some more info, my car was originally a 325is but someone swapped an eta engine in it at some point (found out when I pulled the engine) Is this the remains of that swap?
    My harness doesn't have pins 3,8,9,14,15,17,19, or 20. According to AKG it shouldnt have any of those except for pin 14 (AKG says Oil Fault Level Set, RMEuro and Garagistic say Speed Signal)
    Here are the links that I'm going by:
    http://www.akgmotorsport.com/e30convpins.html
    http://www.rmeuropean.com/bmw-e30-m50-swap.aspx
    Things to note: In our opinion, the best harness for this swap is an early manual 93-94 325I harness. It's simple and can be acquired from any junkyard for cheap. Not to mention, you won't have to sit there and eliminate wires you did not use. However, if you got a harness out of an auto car it can still be used. You c
    • JFarhanbod
      • 2151
      Anyone?
      • !kid
        • 1362
        Perhaps it was wired that way so the check engine light never comes on?
        :borg:
        • JFarhanbod
          • 2151
          The cel worked before I pulled the engine out though
          • JFarhanbod
            • 2151
            On a normal m20 harness is pin 12 brown or the green wire? I'm thinking maybe they spliced and repinned it.
            • JFarhanbod
              • 2151
              Okay it looks like its just an extension pin or something
              • 328ijunkie
                • May 2007
                • 3961
                Looks like theyre grounding the CEL pin from the ECU for whatever reason.
                Check Us out on Facebook
                Full Product Line Tuning
                  • 34847
                  the CEL wire is gray
                  that looks like a pretty bad hack. It looks like it's connected to pin 6 or 7. there's zero reason to do that.. hopefully it wasn't 7 because that's power from the ignition switch, and 6 on some cars is to energize the ABS relay.
                  also, I can't believe AKG still has the wrong pin information on their site after all these years. do NOT use that as a guide if you like your magic smoke to stay inside your harness..
                  • 328ijunkie
                    • May 2007
                    • 3961
                    The brown wire seems like it goes back into the harness which makes me think it was pin 20 (which on some cars is a brn wire) and plugged it into that CEL wire (non original wire) for some reason?
                      • 34847
                      I dunno. either way, it's badly made and doesn't make a lick of sense.
                      • 328ijunkie
                        • May 2007
                        • 3961
                        ^Truf.
                        • JFarhanbod
                          • 2151
                          Well I cut the pigtail and there is no gray wire in the harness at all. Im pretty sure every other color matches up with the guides except for that brown one. If I just splice it can I use pin 12 as the brown one or did they re-pin it and mess everything up?
                            • 34847
                            you'd have to follow that wire all the way to the DME connector and verify the pin. there's no way of telling what it's actually connected to.
                            if you have a continuity tester/DMM, look up the pin numbers for your DME, find which one is for the CEL, then test and see if it's even connected to that brown wire at all. is it straight brown?
                            • JFarhanbod
                              • 2151
                              Alright I'll check that later on because my dad has the continuity tester in his car. Yeah the wire is straight brown. Do you think I would just be better off going to the junkyard and getting another c101?
