Run really rough, backfires, wont idle
  • 5Toes
    • 9836
    Here is what is wrong:
    Starts and fires but wont stay running, if I give it gas it will run very poorly and rich.
    I checked all the coils, they all test within spec.
    Neighbor suggests MAF, so I unplug it and try again. Starts and will stay running at 500rpm super rough. But it runs.
    Removed MAF, no wires broken, SUPER clean.
    What could be my problem?
  • chadthestampede
    • Jul 2008
    • 3601
    Have you done a stomp test?
    Originally posted by LJ851
    Feedback
    • 5Toes
      • 9836
      Oh shit, no I forgot I can do that. Will do later!
      • 5Toes
        • 9836
        Any help?
        • ian e30 318is
          • Mar 2007
          • 1809
          Maybe your idle control valve. Have you tried hooking your engine up to a computer? Any check engine light?
          1991 LS1 Swapped 318is
          Instagram:
          https://instagram.com/saltybeast/
          LS Build Thread:
          https://www.r3vlimited.com/board/for...s-e30-ls1-swap
          • 5Toes
            • 9836
            I am running the codes later today
            Some reading on bimmerforums points to vacleaks or a bad MAF.
            Its weird, because it sat for a week and then did this. I dont know how vac leaks would make it run rich though
            • Slovik
              • Jan 2010
              • 198
              Just a thought but my m62 had the same symptoms when the cam position sensor went bad. Don't know which engine you are running.
              • chadthestampede
                • Jul 2008
                • 3601
                The stupid curved hose under the intake blew out once and did this to me, check that.
                Feedback
                • 5Toes
                  • 9836
                  working on checking the icv today.
                  might pull intake manifold too..
                  • Roysneon
                    • 4505
                    If you mean the one on the other side of the throttle body, that happened to me once too. Took the throttle body off ans saw light shining through the other side lol
                    Originally posted by mbonanni
                    I am a pursit now.
                    • chadthestampede
                      • Jul 2008
                      • 3601
                      mine was this cocksucker
                      Feedback
                      • 5Toes
                        • 9836
                        I got it all apart at the moment, I will keep you all posted what it was.
                        intense maintenance time!
                        also, found a fair amount of oil in the intake manifold. Not worried about it though, my car never smoked
