M50 Wont Fire.. At All
  • Cyrix2k
    • 593
    Originally posted by 5Toes
    Yes I have used a multimeter. I thought BMW's only supply spark if the DME sees a reading from the CPS.
    Its not related to an E30, so whats the problem?
    no ECU will. It needs to know the crank position to know when to fire the spark plugs.
    1997 540i/6 - stock
    1985 325 - M50NV - Getrag 250 - 2.79 LSD - MS2/e -LC-1 - 750cc injectors - Blunttech Manifold - HX35 - AEM UEGO
    1991 318i - M50NV - Getrag 240 - 4.10 open - e36 rack - Smileys - 55w 5000k HIDs
    • dashboardmonkey
      FUCK YOUR WAFFLES
      • Jun 2008
      • 6158
      low compression could be due to cylinder wash
      -Andy
      • brianao34
        • Jun 2010
        • 660
        Kind of a rare but common thing, but I've been reading a lot lately so I could figure out why my S50 wasn't starting and I saw quite a few posts about the keyway for the harmonic balancer shearing off and spinning the harmonic balancer just enough to screw up the timing being as the CPS controls the ignition timing.
        • 5Toes
          • 9836
          Okay, I will look into all this. Injectors are firing, pulled fuel rail and cranked it to see that. I can only see like 3 of them, need a helper to see the rest.
          As far as everything else goes, well battery is near dead so I put it on the charger for now.
          Can somebody maybe make me a list?
          So far I have:
          - check rest of injectors
          - electronically test TPS
          • 5Toes
            • 9836
            this thread has me worried because maybe I did fry my DME. Although I never did disconnect that ground wire near the thermostat
            EDIT: Checked connection for this wire, all good
            • emmanuel.dlc
              • Jun 2011
              • 144
              but you didn't see any of them dripping anyways? they keep dripping for a couple of seconds until the pressure is released.
              on my case, it was a mix of a complete open injector and fouled sparks, it died quick and never turn on again until i dropped new sparks and the bad injector.
              • 5Toes
                • 9836
                Spark plugs are new and still spark. My helper told me the spark was very strong
                • 5Toes
                  • 9836
                  E36 Sensors
                  Located this document so I will test them all today.
                  • James Crivellone
                    Head Janitor
                    • 6304
                    Compression test the damn thing
                    • 5Toes
                      • 9836
                      Located compression tester, I am going to have to add oil... I know the cylinders are bone dry
                      • 5Toes
                        • 9836
                        I should also add that before I took everything apart it would run if throttle was kept open... but very, very roughly and backfiring excessively.
                        • DrJosh
                          • 2011
                          Is it in park
                          Originally posted by Sonny
                          I am a meme for our community.
                          • 5Toes
                            • 9836
                            yes, otherwise it wont crank.
                            weather is too bad to compression test
                            • 5Toes
                              • 9836
                              Problem solved.
                              Charged battery and undud terminals for 14 hours.
                              Cranked it with throttle half way open and it slowly started to fire every cylinder and fired up.
                              Smoked for a good awhile but then drove it around and it is perfect now
                              Thanks guys :)
