So, I'm swapping in a M52 and I'll be using a E34 throttle cable.
I want to know, if the cable needs to be bolted to the driver shock tower exactly the same way the stock E30 cable is bolted?
When I removed my throttle cable from my M42, there was a little bracket that held the cable tight up against the shock tower.
Thanks
Thanks
