I did a swap in my 91 318i last year, m50tu and before the swap my tach worked fine, after i did the swap it didn't work at all. Was at the bottom of my priority list for awhile but last week i hit a bump and it started working, except its off a couple 1000 rpms. the needle sits at Zero when its off but when its idling it says its at around 3k when its clearly idling normal. Any idea?
Need Help with my Tach
Tags: None
Coding Plug. Search pls.
Check Us out on Facebook
Full Product Line Tuning
OBD2 Tuning Available! OBD2 E36, S54 Swap, S62 Swap, etc: tuning@MarkertMotorWorks.com Dyno Thread -
