n/a m50 horsepower
  • Wergen7
    • Jun 2012
    • 255
    n/a m50 horsepower
    i was wondering if anybody knows what a n/a m50 is capable of putting out (since power of course is everything haha). i know lots of people turbo shit but im not sure if i wast to head in that direction or stick n/a. so what have people seen out of a little m50?
    http://www.r3vlimited.com/board/showthread.php?t=267166
    http://www.r3vlimited.com/board/showthread.php?t=380488
  • Dj Buttchug
    • Jun 2010
    • 7687
    s50 cams will get you 210-220 ish crank hp i believe.
    Turbo M42 Build Thread :Here
    Ig:ryno_pzk
    I like the tuna here.
    Originally posted by lambo
    • JJe30
      • 2044
      I have s50 cams, tune, typical headers, exhaust and dyno'd 196whp/175trq and I started to lean out at 6250rpms..
      • ak-
        • 12422
        Not bad man.
        1991 325iS turbo
        • VinniE30
          • 2113
          Full bolt on with S50 cams typically gets around 200WHP or 230 crank HP given 15% drivetrain loss. At least on the usual dynojet. That's what you'll see if you check out the e36 dyno thread on bimmerforums. But take those as you wish because different dynos can result in very different numbers.
          Zinno '89 <24v swap in progress>
          • PeteD
            • 982
            You can get good power out of a NV motor AND with some cams the delivery of the power is smooth to the top.
            JJE30 what injectors are you running, 17lbs?
            • Bimmerguy91
              • Jul 2012
              • 982
              My setup is a m50 nv rebuilt has dual nv intake cams, headers, exhaust, intake, and tune. I'll have it dynoed when it's done
              • tigwerks
                • Jul 2012
                • 42
                Im thinking of doing the same and going the opposite route of my built STI. Im thinking of stroking my M50 and running a 13.5:1 high comp motor on e85 to get some good gains going N/A
                • Bimmer guru
                  • 50
                  Mine dyno'd at 231whp/182trq
                  Has s50 crank, m52 rods/ pistons, s50 cams, #21.5 injectors, tuned by a local place, silicone hoses, and some other small things.
                  It had a ridiculous 3 inch exhaust at the time of the dyno, which I'm pretty sure was helping out the high end, but the lack of back pressure was probably hurting the torque. It leans out at right around 6500 rpms. It is more or less an s50 with an 84mm bore as opposed to a 86mm. Makes it a 2.9. If you're thinking about going the way of the m50, i haven't regretted it at all. Mine ended up being pretty cheap because I got a lot of my parts from junk yards or just had them laying around. Although most people don't have s50 cranks lying around lol. If I could go back, I would probably just go straight to an S52. That will be the next engine in this car.
                  The really interesting thing is how the power hits in this car. Low end is pretty quick, but right around 4,200 rpms it just instantly pushes you back in the seat. Im looking but can't find that dyno file. If i do them I'll upload it.
                  • DooDanE30
                    • Nov 2011
                    • 683
                    awesome numbers for m50. always considered the m50 (not stock though) but i've decided im going s52. i can not wait.
                    • Bimmer guru
                      • 50
                      Good choice man. If you have the money then it will absolutely be worth it. It can be a track car, drag car, daily driver, it is just a very versatile engine. I have a friend who ran a 8.42 at 84.45 mph with a 1.9s 60 foot time. On 195 all season tires lol. He got his s52 for 2400, and it came with another tranny and turner motorsport shorty headers. After he got it in he couldn't believe the difference.
                      • PeteD
                        • 982
                        Bimmer guru, those are some great numbers! I have a similar set up (actual s50 bottom end), but with smaller injectors. I've been waiting to put the 24lb injectors in.
                        • Bimmer guru
                          • 50
                          I've heard around a few places that there isn't really a need for the 24lb injectors and that #21.5 is all that you need. I mean I don't think it will hurt anything. Even if it ran a little rich, that still wouldn't be a huge deal. I've just heard that no matter what you do to these engines, they're gonna lean out around 6,500 rpms.
                          Are you running s50/s52 cams? Because if you are then you more or less have an s50 haha. I'm sure it hauls and is fun to drive.
                          • JJe30
                            • 2044
                            Pink top 19lbs
                            • PeteD
                              • 982
                              Bimmer Guru: Yeah 21 is probably all I need, but the 24lbs were cheaper lol. I have the twin 325is non vanos cam set up - which might be hotter than s50 cams...IDK. The thing is a beast though. I have a 2.93lsd and it still feels fast.
                              OP, I really like this motor. I wouldn't worry too much about putting down a ton of power in this chassis. I don't understand how people turbo these things...I'm being hypocritical because I'm open to the idea, but man, the beefed up n/v m50 is pretty awesome by itself.
                              I'll find my dyno file on the 17lb injectors. I do have a video, which doesn't do much, but I like the N/V M50 pride in this thread. haha
