Hi guys,
I searched around for the Rod/Main bearing clearance, but no much info are around, and am looking for your help here guys.
Am building an engine that use forged internals, as am using eagle rods, with stock bearings, so I wonder how much clearance should be on the Rod and main bearing, knowing that am using ARP main studs, as this engine will be used with high boost, anyone know what it should be? as using plastic gauge to check the clearance.
Thanks in advance guys,
