Tell me what I don't want to hear.
  • Aptyp
    • 6584
    What it is: m50 with a 318ti radiator.
    What it does: temperature creeps up until I am forced to turn the car off. Coolant level drops and top radiator hose is dry after a short drive.
    what has been done: thermostat is new and works. Waterpump is new Graf. Radiator flows perfectly. No coolant leaks. No heater core, so there's not an air pocket there. Car doesn't smoke, there's no oil in coolant and no coolant in the oil.
    Did I miss something, or is it that new engine time?
  • mrcheezle19
    • Apr 2012
    • 1451
    well if there's no water in your coolant that could be the issue right there. Adding water helps the coolant dissipate the heat better. I would add water to the coolant.
    Dude this is r3v. 20 bucks gets you a used timing belt or a low mileage head gasket
    • ian e30 318is
      • Mar 2007
      • 1809
      +1 for the water. Also what about a fan? Sounds like you forgot that. My temp would also creep when sitting still in traffic or at a light when I did not have a fan to force air over the radiator. Wire in a pusher or puller fan mounted to your radiator and it should solve your issue.
      1991 LS1 Swapped 318is
      Instagram:
      https://instagram.com/saltybeast/
      LS Build Thread:
      https://www.r3vlimited.com/board/for...s-e30-ls1-swap
      • K1CKBAC
        • 306
        If you just replaced the radiator it was probably just in need of a top off.
        My expectation is an immediate 5 speed swap. Autos suck more than a 50 year old whore.
        • mrcheezle19
          • Apr 2012
          • 1451
          yeah definitely check your fan as well. Make sure it is working and coming on at the proper times. IIRC it should be 2 stages. one low speed before the half way line and then high speed when you reach the halfway line or go past it.
          • bimmer630
            • 1230
            I think he meant no water in oil and no oil in the water. I can't see a car overheating just because it has straight coolant.
            Might be an air bubble.. I let them sit after a short run then recheck. Does the 318 radiator haveva bleed screw?
            • ieatpeople
              • Mar 2008
              • 883
              i think OP was alluding that the head gasket is letting go....
              do a compression test, let us know how it looks.
              Originally posted by BillBrasky
              That's like Vlad challenging Chip Foose to a car painting contest.
              Originally posted by acolella76
              i'm pretty sure 'Phillis' is short for syphilis
              2007 CVPI, stock and slow
              1994 tercel, 5efhe swap, i/h/e
              1984 t-type, 5.3/th350 swap in progress
              My newest addition:
              Rebecca Arlene, born 4/19/2013
              • Aptyp
                • 6584
                yeah, there's no reason for coolant/water to disappear and top rad-hose become dry.
                Compression test coming up today.
                • e30rapidic
                  • 2167
                  hopefully not a cracked head... check spark plugs as you pull them and see if you have a "clean" one.
                  '87 325ic, powered by S50.
                  • DREWHALL
                    • Feb 2006
                    • 1207
                    Was gonna say, look for the steam cleaned cylinder. If any of the plugs come out looking cleaner than any others or the piston tops, if you can get a look at them through spark plug holes, look particularly clean then you have coolant entering a cylinder.
                    • Mossman
                      • Apr 2006
                      • 1961
                      Coolant has to be going somewhere, if it's going into the cylinder through a head crack or a failed head gasket in any decent quantity you would know it from white exhaust smoke and a sickly sweet smelling exhaust.
                      • future rs
                        • Aug 2012
                        • 514
                        I'm sorry to break this to you. But you're fat....
                        • rightcoastbias
                          • 449
                          My m42/318is radiator required me to jack the front end up ~2' and run the engine for ~20 minutes before it would bleed properly. I have not had a single issue since.
                          *Note: My M52 is running an 82 deg thermostat, 16" pusher fan and the heater core is connected.
                          M52B28 OBD1 - G240 - S4.10
                          Stuff for Sale: 24v swap parts
                          • FredK
                            • 14764
                            Check that you don't have a 1.4 bar radiator cap. It will have "140" printed in the center of cap.
                            You need a 2.0 bar cap. It will read "200".
                            Easy mistake to make, as I've done it before with an M42 radiator.
                            • Jluke
                              • Nov 2012
                              • 5
                              Mabey head gasket leak, if i were you, look for combustion to the water side not water to the combustion side, look for bubbling coolant/smoke coming back through your reserve.
                              Though that's the extreme side, check the simple stuff first, fan kicking on, no lines blocked, water pump working.
                              Also did this happen only one time, or multiple times. Just once might be an air pocket, more than once would be bigger problems.
