Coolant temp sensor help
  • kelzzrocka
    • Nov 2011
    • 408
    Hey , hopefully someone can help me out, my temp gauge is not working I changed my temp sensor to the m20 and re-wired the wires on the c101 to the x20 connector but still no reading???!!! just want to make sure is the wire colors brown n purple on both sides #4 on c101 to #12 on x20? Because I also read that it's the connector #4 from the c101 (brown/purp) to #12 on the x20 connector which is (brown/yellow). Can someone clear up the wire colors for me n I have searched that's why I'm not sure what color wires should be connected (the PO had done a hack job so I don't have the original m50 side connector).thankss
  • BergerNJ
    • Oct 2009
    • 349
    Are you sure your gauge is even working properly? Most temp gauges fail from a handful of issues. Bad board, bad wiring right behind the panel, a screw can be loose(or two)....Seriously, pull the panel and inspect everything.
    • kelzzrocka
      • Nov 2011
      • 408
      It was working before I had started my engine swap , but ill check the connections . And just to be sure is my wiring right?
      • MaxBell
        • 1391
        What car do you have?
        REMEMBER: Be safe and have fun is Rule Number 1.
        The Epic Unbuild of Clint Eastwood
        • kelzzrocka
          • Nov 2011
          • 408
          1989 325i and the motor is off a 92 325is
          • kelzzrocka
            • Nov 2011
            • 408
            Anyone??!
            • ForcedFirebird
              • Feb 2007
              • 8300
              Test continuity from the sensor plug to the c101 wire.
              john@m20guru.com
              Links:
