Which Coolant Temp sesor?
  • 1990m3
    • 1180
    In the long thread at the top it says to use an M20 temp sensor in place of the M50 one when doing a swap. Well, my car started as a 318is so does that mean I should use a M42 temp sensor?
    Thanks
    dave
  • Garageaholic
    Freestyle Fabricator
    • Dec 2005
    • 5204
    Thanks
    dave
    When it comes to the temp gauge, I would stick with whatever gauge you had originally with the car. The M42 sensor
    If all else fails, try each one. I know it's a bitch, but if all else fails....
    In my M30 conversion, I was told to stick with my regular stock M20 sensor..
    Recent Rebranding!!
    E30 SM62/S62
    E30 M60 V8
    E30 M30 Big 6!
    Instagram.com/garageaholic
    Youtube.com/garageaholic
    • 1990m3
      • 1180
      see that's what I figured, but I'm just looking to make sure.
      Thanks
      • KangamangusDriver
        • Aug 2005
        • 1870
        The M42 sensor will work.
        It worked for me fine
        • 1990m3
          • 1180
          thanks
          • aeryk7
            • Oct 2005
            • 616
            Well i ran into a problem when hooking up the wiring harness and found out i needed 2 x 2 prong coolant sensors because the harness only came with one one prong connector which went on the back of the e36 oil filter housing .
            253rwhp
            My Vids(OLD)
            http://www.youtube.com/user/aeryk7#p/a/u/0/hS4ZAzSdUdY
            http://www.youtube.com/user/aeryk7#p/u/2/C-0hnV2k_xU
