Swapped my thermostat yesterday since I figured that was my problem, the car does now come up to temperature while idling but after a minute or two of driving it drops to just above the blue marks on my cluster.
Emptied and bled the whole system for a few hours to the point that when I get back home after a 40min drive there's a quick "pfft" noise when I crack the bleeder screw, but that may be a result of the the thermostat not opening due to it never reaching operating temp while driving.
The other thing, I have like no heat in the car - it's KINDA warm while idling, but freezing cold while driving. Radiator doesn't appear to have leaks, I'm able to push water through the heatercore.
The only things I've done as far as customizing the cooling system is deleting the check valve for the heatercore (since I always want it running through it)
and deleted the Throttle body heater lines (runs back to the block.)
I should also note that this was the same issue I had in the summer, but with the weather being in the mid-thirties lately it's been considerably worse!
