Loose vanos cover bolts?!
  • spiDmang
    • 3941
    Has anyone ever had issues with their m5x/s5x vanos housing bolts coming loose?
    I cracked up the valve cover to replace the valve cover gasket to find my vanos cover held on by the 5 bolts that were almost backed out to the point of grenading the engine! (literally, the picture shows how i found the bolts)
    Its not shown here, but there is a bolt near the bottom of the cover that i CANT reach for the life of me. Do you guys recommend removing the vanos, and tightening down the cover bolts w/ locktite, or is there some magical way to get a wrench in there to get that badboy nice and proper?
    HELP!!
    91' 318iS - S54/6MT Swapped
    08' E90 M3 6MT - Daily
    Originally posted by IronJoe
    Originally posted by 2mAn
  • FredK
    • 14761
    Yes. This EXACT thing has happened to me. I actually rebuilt a VANOS with the Beisan Systems kit, torqued the bolts to 89 in-lb with a in-lb torque wrench. After around 16K miles of driving I pulled the valve cover. I saw these bolts had backed off even more than yours.
    So, I removed the VANOS and rebuilt it again, this time tightening to 89in-lb and snugging the three bolts a touch more. There might be a way to do this without completely removing the VANOS but you'd probably need a half moon wrench or somethign weird like that.
    • spiDmang
      • 3941
      Damn...that is sooo sketchy. Did you end up using locktite on the bolts when you re installed everything?
      Yeah, I can basically get all the bolts snug besides the bolt at the very bottom of the cover. wish i could have snapped a pic of it before leaving for class. I'd hate to remove the vanos, to have them back out again.
      • FredK
        • 14761
        I did use blue loctite on the bolts to be extra sure. Honestly though, with a slightly extra snugging they won't back out. I rebuilt another VANOS for another engine, just doing the extra snugging step with no loctite and they didn't back out after around 20K miles.
        • bimmer630
          • 1228
          maybe use new nuts too.. BMW always recommends replacing the pinch style nuts
          • bimmer630
            • 1228
            ...But i dont know if those are locknuts so my comment may be stupid
            • spiDmang
              • 3941
              From my experience, I can't get the bolts fully out, with out removing the vanos >__<
              • 328ijunkie
                • May 2007
                • 3961
                I always overtorque them a smidgen because of that. Ive never had them backout :dunno
                Check Us out on Facebook
                Full Product Line Tuning
                • spiDmang
                  • 3941
                  Is there anyway to do this without removing the vanos?
                  • sharky
                    • Jan 2005
                    • 2672
                    no remove it, new nuts and locktite. Had this happen to a customers car and it deystroyed the engine
