Any difference between the 2002 and 320i boosters as far as performance?
Anyone know what the already converted Zionsville Autosport booster is made from?
The brake booster has nothing to do with locking the rears up before the fronts (which is a serious condition that needs to be addressed). All it does is assist with the transfer of forces to the master cylinder (see below). If you can explain how, in a system like this, that you can increase rear bias (or reduce front bias) by using an E21 booster, I would love to hear it.
All it does is assist with the transfer of forces to the master cylinder (see below). [/IMG]
agreed. ummmm......that diagram is a little off though. the vacuume is on the wrong side of the diaphram. the vacuume is to pull the diaphram towards the master....(assisting the force from the pedal.) cheers, jason
i believe the E21 booster is smaller. I bought both and went with the E21 due to it's size. It fit in my car with zero clearance issues on the S50 intake manifold. I didn't take measurements, but once I placed the ix booster in the car it was a no brainer for me. You will most likely have to remote mount your reservoir on YOUR swap no matter which booster you go with. But you'll definitely have to remote mount with the ix booster. I don't know how far out your intake setup comes in relation to an S50, and I have a feeling your motor sits at a different angle than the S50, more similar to our beloved S14's!
Ron, you may want to contact Cahsel for a 2002 brake booster. Located in Netherland.
Or 2002faq.com, the US 2002 forum.
The 2002Tii is even smaller in diameter than a regular 2002 booster. A tad bit longer though.
Just bumping this one way back up - anyone got the tap size on the bolt for the booster rod?
-Charlie
charlie - taken from one of my old posts.
cheers, jason
BOOSTERS COMPARISON
E30 stock booster
10.75” diam x 4.5” thick (firewall to master mounting face)
Firewall mounting holes = 2-7/8 x 2-7/8”
Firewall center hole req’d = 2.37”
Firewall to end of threaded rod = 4.125” (m10x1.5)
Master studs = 2.37” c to c
Master bore hole = 1.67”
E21 320i stock booster
9.5” diam x 3.5” thick (firewall to master mounting face)
Firewall to end of threaded rod = ?????” (m10x1.5)
