bending g260 selector rod
  • bimmer630
    • 1230
    Does anyone who's done the swaphave pics of how much they newses to modify the selector rod? I have the modified trans brace but I fogired if I could get specs/pics on the modification I can do it now so it'll be ready when I install everything. Thanks
  • frankie591
    • Feb 2012
    • 545
    twist the rod 10 degrees. 1 end in a vice, adjustable wrench around the other end, heat if you wish but I didn't need heat to twist mine. Another way would be to cut it, align the pieces 10 degrees twisted and weld it back together.
    • bimmer630
      • 1230
      Sweet thanks
      • drez14
        • Jun 2011
        • 211
        FYI also.. If your running a short shift lever or ever plan to and your driveshaft has a dampner donut, you will need to bend it clear that as well.
        • frankie591
          • Feb 2012
          • 545
          I took my vibration damper off and have not had any problems.
          • drez14
            • Jun 2011
            • 211
            Crap, they are removable? i thought they are riveted in.. I would have done that too..
            • frankie591
              • Feb 2012
              • 545
              the bolts that hold it on are splined so you just hammer them out of the driveshaft, remove the damper, then hammer the bolts back in.
              • bimmer630
                • 1230
                Mines already gone. It hit with stock drivetrain and z3 shifter
