I just got my swap up and running. I have two things that I have noticed with the e34 cable (the one that craiggroves recommended in his swap diy).
#1 my throttle is pretty twitchy and sticks at the top of pedal travel. As Dave said earlier it might be a vac leak, which could help explain my crappy idle also, so I will have to check that before pointing fingers here.
#2 lots of extra slack. between the firewall and the grommet location on the TB, I have a lot of extra cable kinda looped up around the intake boot.
Is the e36 cable any better?
edit: also if i put this cable on the cruise pulley it holds the throttle open about half way, so it only works on the bottom pulley. IDK how you guys can put it on either.
