E30 m52 gear linkage???
  • Driver0122
    • Dec 2012
    • 4
    Hi, new to the forum. May have already covered topic but struggle to search on phone sao help needed :)
    Rite, building e30 m52b28 with e36 328 gearbox, prop.
    Q. What selector+ linkage do I use as having issues with it popping out of 2nd and not quite reaching reverse useing m20 2.5 linkage at moment and no good
    Any help appreciated.
  • I*Do*Werke
    • Dec 2010
    • 259
    Use the entire linkage from the e36 328 gearbox. I also suggest using the z3 short shifter for an improved feel
    ^M52B28^
    • Driver0122
      • Dec 2012
      • 4
      Cheers
      Do I need to change the part that the is mounted to che chassis as I'm sure the e36 selector was hitting the prop.
      • I*Do*Werke
        • Dec 2010
        • 259
        You shouldnt need to. In my e30 with m52 and e36 trans, I have the complete e36 linkage, e30 body mount, and z3 shifter
        E36 linkage --> http://www.realoem.com/bmw/showparts...13&hg=25&fg=05
        E30 linkage mount #4 only --> http://www.realoem.com/bmw/showparts...27&hg=25&fg=05
        ^M52B28^
        • Robert
          • Dec 2010
          • 3770
          I have both e36 linkage with brand new AKG Front bushings, lemme know if you're interested. $40 shipped for both.
          • Driver0122
            • Dec 2012
            • 4
            Will try this weekend as I have parts already. Got an e34 with z3 shifter that I will steal :)
