Shim the sway bar down or the motor up, either better?
  • madsedan
    • 222
    My OBD1 s50 manifold is intermittently hitting the sway bar on left hand turns, and doing searches I found threads where people were shimming the sway bar down and others where people just put fender washers on the motor mounts.
    I just dropped my car with Bilstein/H&R race and I'm on 14" weaves so my oil pan is pretty low. I was thinking shimming the motor up would help with manifold rub AND a little more pan clearance, is this a good idea r a bad one?
    I will shim the motor up the same amount on both sides but would like some input before deciding which way to go.
    Also, how much is enough or too much, is 1/2" ok?
    '91 318is, S50 swap, Bilsteing/H&R race, Recaro SRD, etc.
  • frankie591
    • Feb 2012
    • 545
    Anytime you move the motor up, you are putting more angle on your driveshaft u-joints. If it were me, I'd move the sway bar down
    • M3PO
      • May 2012
      • 537
      Agreed. I wouldn't play with the drivetrain alignment.
      • SkiFree
        • Jun 2011
        • 2766
        Howabout a potentially better option.
        running u-locks next to the pivot bushings to keep the bar from sliding back and forth.
        ADAMS Autosport
        • bmw325csi
          • May 2007
          • 4045
          My engine has been raised for 2 years now with no issues what so ever
          harry/harout
          • madsedan
            • 222
            Is there an aftermarket sway bar option that would take care of the clearance, maybe one that uses a different mounting point?
            • greyis89
              • 230
              Fix it before it's too late. Had the same problem and the pipe tore off the sway bar mount on the subframe. Instead off replacing the whole subframe to actually have a mount tab for the sway bar, I had the exaust all customed for clearence and had a tab welded for a mount. I needed a good exaust setup anyway so it was a good time to fix it all at once. No problems since. Hope you get it sorted out.
              • Northern
                I like cupcakes & sh!tboxes
                • 5284
                My engine has been raised up more than an inch for a year now and my guibo and CSB still look fine. They weren't new when I bought the car either.
                Saved my oilpan a number of times.
                Originally posted by priapism
                Originally posted by shameson
                • thisizaremix
                  • Jul 2011
                  • 60
                  The u-joints are supposed to operate at a slight angle. Raising your engine does absolutely nothing to affect anything.
                  • Northern
                    • 5284
                    Well, CofG I guess.
