Flywheel gurus, I need help!!
  • spiDmang
    • 3941
    Hey guys,
    So I have a 633csi m30 flywheel (14.5lbs) in my s50 that I just swapped into my eta. I've been told thru multiple sources that the 24v starter will work with this combo, but when I go to start the car, it seems as if the starter is jammed up and not working with the flywheel?
    Any ideas guy? Any help would be greatly appreciated :(
    91' 318iS - S54/6MT Swapped
    08' E90 M3 6MT - Daily
    Originally posted by IronJoe
    Originally posted by 2mAn
  • rav320uk
    • Jun 2004
    • 1337
    Why not use an M20 flywheel?
    If you have bought items from me, please leave feedback below.
    If you are a BUYER, Check My Feedback.:up:
    http://www.r3vlimited.com/board/showthread.php?t=183860
    Check out my Euro Build Thread
    http://www.r3vlimited.com/board/showthread.php?t=215557
    • spiDmang
      • 3941
      Because supposedly the m30 flywheel is supposed to work with the 24v starter
      • rav320uk
        • Jun 2004
        • 1337
        Not as far as I know.
        No one over here has ever used the M30 flywheel.
        M20, lightened to about 6kg.
        And it's more so to do with the starter not having the right amount of teeth for it to mate with the M30 flywheel.
        • RoadHazard
          • Sep 2007
          • 163
          One of my friends is using the M30 flywheel with his M52 engine (and M52 starter.) So I suppose it should work.
          What starter are you using?
          90 E30 S50B30
          http://www.fquick.com/roadhazard/
          • rav320uk
            • Jun 2004
            • 1337
            Is the battery FULLY CHARGED??
            • ZekeTheSneak
              • 1562
              If you end up using an m20. I know a cheap place to have it milled down, I did mine.
              • rav320uk
                • Jun 2004
                • 1337
                Count the teeth on the M5x starter, if it is to work with the M30 Fly, it should have 9 teeth
                • spiDmang
                  • 3941
                  Ok I'll try this out, and report back soon. I just caught a cold :(
