I have my tach all wired up as it should be and it works but as you rev it up it goes up way to fast and in no time i'm at 7k and it seems to be only running at like 4-5k maybe. Any clue what this would be?
Tach Trouble
Tags: None
Ok so like is there somewhere to get that or do i need a new cluster? The cluster was in the car and it was a 6cyl that's what i don't really understand. Is there maybe a write up on here about it?Comment
ETA coding plugs only work sometimes so just cause its from a 6cyl car doesnt mean its guaranteed to work.
Check Us out on Facebook
Full Product Line Tuning
OBD2 Tuning Available! OBD2 E36, S54 Swap, S62 Swap, etc: tuning@MarkertMotorWorks.com Dyno ThreadComment
The coding plug is that little guy on the front right of the cluster when you remove the trim panel between the steering wheel and the cluster. Just squeeze the tabs and pull it out. I just did this a few moments ago; all fixed!1991 349is (wadded up)
1984 Rabbit 2.0L16v swap (wife's)
2003 LR Disco II (wife's)
1993 MB 400SEL (son 1's)
1980 MB 450SEL (son 2's)
2004 KTM 525 EXC-R SM Sold:(Comment
