Flywheel removal?
  • amcink
    • 788
    Flywheel removal?
    Any tips on how to take the flywheel off? The bolts are very thight and the crankshaft turns. the engines is on a hoist and i need to install it on the engine stand
  • efficient
    • Feb 2012
    • 3312
    I boughtt a flywheel stopper from some vw website for like 13 dollars.
    Vintage VW Parts, Classic Volkswagen Parts, VW Bug Parts, VW Beetle Parts, and VW Bus Parts.
    • Xat1cZ
      • 2020
      I've never had any problems with that when using an air impact wrench...
      • ghalee30
        • Jul 2011
        • 614
        hit your rachet with a 5lb mallet or hammer
        should do the trick
        • AndrewBird
          The Mad Scientist
          • 11898
          I put a breaker bar on the front of the crank and let it stop against the ground. If you are facing the front of the engine, it should be sitting down on the right side.
          • eurosport22
            • 210
            ^ that is what i do if i dont have an impact.
            • Beej '86 325es
              • 2639
              http://www.jbugs.com/product/7015&Store_Code=JBUGS.html
              That's an interesting part. What does it bolt into?
              -Brandon
              '86 325es S50
              '12 VW GTI Autobahn DSG
              '03 540i M-Sport (sold)
              '08 Jeep SRT-8 (sold)
              For sale:
              S50 TMS chip for Schricks
              • Cyrix2k
                • 593
                should do the trick
                don't do this if you value your ratchets. Use a wrench or breaker bar instead.
                1997 540i/6 - stock
                1985 325 - M50NV - Getrag 250 - 2.79 LSD - MS2/e -LC-1 - 750cc injectors - Blunttech Manifold - HX35 - AEM UEGO
                1991 318i - M50NV - Getrag 240 - 4.10 open - e36 rack - Smileys - 55w 5000k HIDs
                • efficient
                  • Feb 2012
                  • 3312
                  didnt notice i was in the wrong section. i used it on a m20 but i put it on were one of the trans bolts goes thru.
                  • Beej '86 325es
                    • 2639
                    Cool. It should still work for the guys like me using the G260 tranny.
                    -Brandon
                    '86 325es S50
                    For sale:
                    • KillaCams
                      • Mar 2008
                      • 998
                      I've done this a few times, this is your best bet for sure
