Diagnostic plug not used, eh?
  • bimmer630
    • 1228
    When I rewired my s50 harness to mate up with the c101 connector, I think I remember noticing the diagnostic line from the DME didnt get used? I may be wrong since It shouldnt even be going through that connector... But after getting my swap wired up and started last night, I attempted to connect to the car with our bootleg DIS system, and it wouldnt connect.
    It would be nice in the future to be able to get codes etc.. out of this thing if I ever run into problems
  • 328ijunkie
    • May 2007
    • 3961
    First off you need a true ADS cable to talk to OBD1 and second off yes, it has to have power through the C101 in order to work properly.
    Check Us out on Facebook
    Full Product Line Tuning
    • bimmer630
      • 1228
      I dont know what ADS cables are. We have BMW Gt1/DIS/Modic software.. with the yellow diagnostic head
      • brenE30
        • Aug 2009
        • 120
        PM'ed you
        • e30user
          • 36
          This is an interesting topic. Why so secretive? I'm jealous.
            • 37828
            The diagnostic port should absolutely work if you wired the harness correctly.
            Classic BMW Specialists
            Grover Beach, CA
            www.BimmerHeads.com
            • bimmer630
              • 1228
              yeah I got it wired up right now. The chart I originally used to convert the harness didnt have one of these " C101 pin 6 to X25 pin 22 and C101 pin 16 to X25 pin 17" I forget which one it was but I didnt have one of them connected. Thanks Bren30 for clarifying that
              • e30user
                • 36
                Thanks. I don't know how I got to thinking this wasn't possible.
                • bimmer630
                  • 1228
                  My sia oil reset and check engine light work too! This swap is kinda neat
                  • e30user
                    • 36
                    Yea, the check engine light is definitely helpful, especially with the stomp trick to get flash codes. It's also necessary for those that want to get the swap BAR'd/legalized in California. I'm not sure what extra work is needed to have BAR pass an obd2 swap, but man I wish I had obd2 diagnostics at times.
                    • bimmer630
                      • 1228
                      We have a chinese copy of BMW factory diagnostics (DIS) at the shop, so its cool to be able to connect to the thing, although OBD1 doesnt really seem to show much info anyway
                      • bimmer630
                        • 1228
                        Where does everyone have their diagnosis plug mounted?
                          • 34835
                          the DME k-line doesn't go through the C101.
                          • EN318isPDX
                            • Oct 2007
                            • 4373
                            Next to the fuse box
                            • bimmer630
                              • 1228
                              I thought that round mount on the M3 trim parts I bought was for the C101 connector (??) My Diag plug would probably reach but right now the ground and Batt + leads are connected on the passengers side and they are branched off really close to the diag connector.
                              And Whats with your airbox? is that a gutted E30 air meter with an HFM stuck inside somewhere?
