Those of you running M20 clutches still (another failure)
  • ed94r
    • Mar 2004
    • 382
    IMO:the stock M20 PP has plenty of clamping force, even for a hot S50/52. What it doesn't have are robust PP straps. 7K kills the straps, not the clutch material.
    I believe there's a place that can add PP straps to a standard PP. I swear it was Southbend Clutches...but could be wrong. It's what I was about to a few years ago, but went with the Clutchmasters kit instead. No problems after that!
    VIR owns 2 of my stock M20 PP's.
    No more after Clutchmasters.
    1988 E30/S50...now with S52; Track
    1994 Miata R; ES Solo2
    1998 Lexus LX470; Wife (Slee'd anyway)
    2002 BMW 530i; A+ Commuter
    2002 BMW 325iT; Sport/Premium 5-speed
    2011 21' EconoTrailer
    • plain325
      • Mar 2004
      • 163
      I have a clutchmasters m20 unit. The modify a sachs PP by adding more straps at each location. There are 4 straps instead of what i believe to be 2. I guess the problem is "stock" m20 clutches
      • 328ijunkie
        • May 2007
        • 3961
        yeah that would prob work.
        Got it up and going with a M52 FW/Clutch/pp.
        I miss the 16lb m20 flywheel though...
        At least now i have a threaded starter... lol
        Check Us out on Facebook
        Full Product Line Tuning
        • einstein57
          • Jun 2007
          • 10780
          Used aluminum m50 flywheels are cheap.
          www.gecoils.com
          • LJ851
            • 7919
            Originally posted by LJ851
            You could also get it rebuilt and beefed up (more straps) and more grip if you want. Great work at a good price here:
            http://www.clutchspecialty.com/
            I give up.
            Lorin
            The M30 is God's engine.
            • 328ijunkie
              • May 2007
              • 3961
              Anyone running a built pressure plate?
              • 36brua
                • 689
                minor bump here...
                I'm changing from M50 >S52
                Current set up is M20 SM FW / M20 PP/Disc
                M20 set up is new w/about 2K miles. so not ready to change to240mm FW
                (no FW with S52)
                This is pretty much a DD with some occasional 'excess'
                I would like to end up with a bit of a cushion the upside of torque rating for S52= 240+- ft/lb.
                have searched & researched etc
                What is the ft/lb torque rating for the stk m20 2.5 PP/disc. ?
                M3 '618'. = ?
                Cluch Mater Stage 1?
                South Bend?
                Thanks for your comments about usage road,drift etc for M20 PP. Would like to get this done first time. I hate removing trans ! TIA
                My CA legal M60 swap
                The happening in our garage
                • 328ijunkie
                  • May 2007
                  • 3961
                  I ran ~215whp through the M20 stock setup for 14K miles just fine. The PP straps were the weak point. Stock M52/S52 clutch/fw setup will hold anything you can throw at them NA.
                  • Cynical 1
                    • Nov 2012
                    • 129
                    i sure can't find a cheap one...
                    1988 325 "super ETA" - Hilde - M52B28 swapped...
                    1969 2002 - Griselda - 20VT AWP swap and full resto in progress...
                    project blog - http://www.cynicalmotorsport.blogspot.com/
                    • TimKninja
                      • 2131
                      Anyone consider one of those Fleabay Stage 1/2 clutches? I might...
                      1985 325e M50TU(Sold)
                      1991 318is Slicktop (Sold)
                      1990 325is Brilliantrot S50/5 Lug Swapped.
                      1992 525i Manual shitbox Winter Beater
