reservoir choices for IX master?
  • pruneball
    • Mar 2012
    • 102
    I was wondering if there were any options for reservoirs on the IX master cylinder. I have not been able to track an IX reservoir down.
    Will another type work?
  • cmeptb13
    • Apr 2011
    • 121
    Why don't you post a photo of what you have. I bought an "iX" booster that turned out to be something more like a 7-series booster. I made it all work but yea I had to search around for the correct MC and the reservoir. If it's an actual iX master cylinder then an e30 reservoir should work.
    • bubbajan21
      • 1962
      2002tii remote reservoir;
      • graphikg
        • Jan 2008
        • 1614
        ^^^ Thats what I got.
        • GunMetalGrey
          • Dec 2010
          • 1499
          DSM remote reservoir works great, sand off all the Japanese lol.
          Take the part that pushes into the master cylinder off of the DSM as well, those push right into the IX res. It's decent and cheap and with a little paint looks good, just make a mount and you are good to go!
          • ScHpAnKy
            • 1573
            e32 one works, iX one works, and I have the 2002tii in mine with the e32 lines.
            91 318i | 87 535iS
            • pruneball
              • Mar 2012
              • 102
              thanks for the info. the original e30 reservoir won't fit. I'll post a pic and see if anyone can tell me if it truly is an ix booster.
              • pruneball
                • Mar 2012
                • 102
                Is the correct? I have an ix booster installed, and no clearance.
                • ScHpAnKy
                  • 1573
                  Originally posted by pruneball
                  [;MG]http://sphotos-a.xx.fbcdn.net/hphotos-snc6/308046_571989919478640_48767715_n.jpg[/IMG]
                  iX/e32 booster for sure, but even I had to shave some fins off the intake manifold. Not much, just a couple where it rubbed. Alternatively, you can raise the engine but it's a hassle if you didn't do that to begin with.
                  91 318i | 87 535iS
                  • Roysneon
                    • 4505
                    Either an iX or e32 res will fit on the master, but it won't clear the throttle body if you keep the booster spacer. You'll have to use the remote boosters mentioned above.
                    Originally posted by mbonanni
                    I am a pursit now.
                    • Gooch
                      • Dec 2006
                      • 1674
                      *PIC*
                      Remove the spacer from the back of the booster and mount it directly to the firewall. This will force you to thread and cut the clevis rod and slot the holes in the firewall as required, but you will be good to go with minimal (if any) intake shaving. Your master will now also clear the intake boot.
                      '91 318is - OBD-II S52 swapped - E30 M3 5-lug - 5x120 BBS RC090 (E39 Style 5) - TCK D/A coilovers 550/700 [SOLD]
                      '87 535i - Vacuum brake conversion [SOLD]
                      '93 525iT - 5-speed swap - 320k and counting
                      '09 328xi - 6-speed
                      • pruneball
                        • Mar 2012
                        • 102
                        We ended up flipping the spacer 180 degrees. The spacer tilted the booster upward. this way it tilts it downward towards the driver side. Plenty of clearance now! Why has nobody recommended this?
                        • Mr.SWISS
                          • Nov 2005
                          • 1251
                          Not much experience in plumbing huh....
                          Water seeks it's own level, and incline promotes flow, or inhibits it. With the design of pulling clutch off the top and brake off the bottom the design ensures if you lose your clutch, you still have brakes since they draw off the bottom of the res.
                          You change the tilt, you change the min amount of fluid the res can operate effectively in those conditions.
                          But if you kept the fluid filled you may never have an issue...ever.
                          Originally posted by 325Projectz
                          don't listen to the diagram... listen to mr. swiss.
                          :nice:
                          • pruneball
                            • Mar 2012
                            • 102
                            I've actually built a sewer pipe before and understand water/turd flow dynamics.
                            I am using a remote reservoir, therefore the angle I created by flipping the spacer is negligible.
                            I should have been a bit more clear when I said tilt. It's minimal just like your concern. How often do you run your car out of hydraulic fluid?
                            The amount of room this creates is well worth checking your fluid levels regularly. Which I'm sure you do, right?
                            • IronFreak
                              • Dec 2012
                              • 3702
                              I have a buddy that has a few. PM me if you're interested
                              Instagram @rebellionforge
