I was wondering if there are any tricks or what you have to do to remove the oil pan. Someone said remove the trans but I'm just making sure. Thanks
m52 oil pan removal
Tags: None
Alright thanks a lot. I'm guessing a car lift would make this a much easier processIf you're not going to do it right, please don't take it out on your car!Comment
If you have a G260 (E30 325i/iS trans) you will need to pull it out to access the rear bolts.Comment
Yea I have a 260 but I need to replace it anyways so it's coming out already. Next weekend I'm getting her up on a lift and replacing my trans and pan gasketIf you're not going to do it right, please don't take it out on your car!Comment
Yea I only have the driver side in cause the passenger side is impossible to get toIf you're not going to do it right, please don't take it out on your car!Comment
