Misfire impossible to diagnose, finnaly diaged with bmw inpa
  • chris_rai
    • Sep 2009
    • 99
    Hi there
    got a very weird problem with my M52 swap since the transplant, misfires on cylinder 1, 2, 3, with injector cut off.
    02 sensor
    6 coils and spark plugs
    Injectors are good
    all intakes gaskets and o ring
    Oil seperator
    are brand new
    i'v finnaly installed inpa on a laptop and diaged it
    got strange battery and ECT readings
  • Mr.SWISS
    • Nov 2005
    • 1251
    coils properly grounded to VC? 1&6 have straps?
    Originally posted by 325Projectz
    don't listen to the diagram... listen to mr. swiss.
    :nice:
    • dsobering47
      • Oct 2007
      • 697
      misfire at 5728 rpm? WHY do people have to rev their engines when theyre not running well? Doesnt make any sense at all.
      Like Mr.Swiss said, check yo grounds.
      • chris_rai
        • Sep 2009
        • 99
        Yes ground straps on 1 and 6 are brand new.
        The engine main ground is on the driver side, stock e30 location
        There is no issue at low revs and part throttle, only wot and high rpm
        the ECU will shut of injectors.
        • Mr.SWISS
          • Nov 2005
          • 1251
          Get a new DME/ECU now and save the journey.
          :nice:
          • chris_rai
            • Sep 2009
            • 99
            hmmmm... this is the second DME i'm trying.
            I bought the DME from markertmotorworks, the 1st one was tuned by technica, with a known bad tune, and it has been replaced by this one, tuned by TRM.
            looks like a low voltage in the DME don't allow the coils to ignit above 5000 rpm, on cylinder 1 2 3.
            • chris_rai
              • Sep 2009
              • 99
              read the codes another time, and it will misfire at same RPM +-10...
              • Slovik
                • Jan 2010
                • 198
                Chris can you point me to where you bought your diagnostic program and was it very difficult to install, most of the ones I have seen are set up as virtual machines and really a pain to install and use. Thanks, didn't mean to put this off topic.
                • DesertBMW
                  • Aug 2011
                  • 1043
                  it is posible that you did not connect the SAP valve silenoid, VANOS actuator, camshaft sensor, the correct way, it is easy to mix them up, I have seen people do this
                  • chris_rai
                    • Sep 2009
                    • 99
                    We cannot invert camshaft and cranckshaft sensors, plug are different
                    vanos actuator is the last plug in the injector harness
                    and there is nothing plugged to the sap solenoid plug since it has been deleted by the tune ?
                    • Mr.SWISS
                      • Nov 2005
                      • 1251
                      What M52 do you have? An M52B28? M52TUB28?
                      :nice:
                      • chris_rai
                        • Sep 2009
                        • 99
                        E36 M52B28, single vanos
                        • chris_rai
                          • Sep 2009
                          • 99
                          Mr swiss is right !!
                          iv finally found someone in my town with swapped E30, tried his DME, and GUESS WHAT ?? NO MORE MISFIRE ! RUNS PERFECT !!
