1989 325i manual
1995 S50B30 US
1994 325is manual harness
413 red label DME with TRM tune for S50
Modified C101 connector to X20 connector (no adapter)
Cranks awesome. Main relays are not turning on. There is 11.x volts at two of the wires at the main relay, 1.4x volts at the other two, and 11.8v at the ground on the relay. The main harness ground (at the battery tray) is getting 1.5x volts also. 525 ohms at CPS too (and it's plugged in to the proper connector.) 11.5 volts at pin 7 C101 (E30 switched ignition wire.)
Obviously, one of my grounds is getting power. What did I do wrong?! I don't even know where to start...
Thanks guys!
1995 S50B30 US
Thanks guys!
