I e-mailed TCD yesterday and they said that their m50 manifold fits in the e30 application, but can't find any pics or info with more details. Anybody confirm? Use it? Pics? Bueller?
					TCD bottom-mount manifold M50
 2003.5 Imolarot M3: daily
 1995 Alpinweiß M3: hpde
 Bottom mount cast manifold vs a top mount tubular manifold. Charge piping is more complicated, usually requiring a new passenger side engine mount, and depending on how low the turbo ends up being mounted you most likely will need a scavenge pump. Looking at the system as a whole you would probably save some money with a top mount. Either way I approve.
 Spa bottom mount, but just for reference.
 You will be probably be limited on turbo selection as well, they typically need to be an on-center type.Comment
 The way I look at it is this; If you're going for lots of power, you gotta go tube mani/twin scroll. If you want decent power from a DD, you can't beat the packaging of a TCD log manifold.
 Whodwho is correct on turbo selection, OC housing only with TCD manifolds. Todd did a really good job choosing the turbos to go with his manifolds. When I purchased an m30 kit from him years ago, the turbo he suggested I start with was the perfect compromise between power and response. I would suggest picking up a turbo from him if you get a manifold.Comment
