HELP- M50 turns over, and thats about it
  • Widebody325
    • 417
    So I got my M50 wired up using AKG's diagram. The motor turns over like it should, but thats about it. I used a volt meter, and I dont have any spark, fuel pump isnt kicking on, and injectors arent firing. So im pretty much screwed. I almost think it could be a fried ECM, just because im getting nothing. Does anyone have any suggestions before I start spending money?
    Follow me @baysidefabrication on Instagram
  • aeryk7
    • Oct 2005
    • 616
    I have a whole thread about it but yeah your engine and ECU are probably not ground properly. Also check to make sure you have the right relays plugged where they belong . the harness i got had a 5 prong in a 4 prong connector ,means that thing aint working.
    I didnt get any spark from my coils until i ran a ground wire from a coil a the strut tower.
    253rwhp
    My Vids(OLD)
    http://www.youtube.com/user/aeryk7#p/a/u/0/hS4ZAzSdUdY
    http://www.youtube.com/user/aeryk7#p/u/2/C-0hnV2k_xU
    • Widebody325
      • 417
      I'll throw a ground from a coil to the strut tower and see if that helps, be right back...
      • Addissimo
        • Mar 2004
        • 1820
        Thats a good call-
        if the ecu doesnt sense spark, it wont fuel, and vise-versa.
        Also check to make sure the ecu is getting power, and is being grounded properly.
        It sounds to me like its a problem dealing with the power to you ecu.
        -Addis
        Doing something M50 related? -> http://www.addissimo.com
        On Myspace? ->http://groups.myspace.com/r3vlimited
        BF2142 SN = BillyGoose
        • Jordan
          • 12913
          AKG's diagrams are WRONG.
          I thought this was common knowledge?
          https://mtechniqueabs.com/
          • Widebody325
            • 417
            Alright. I rewired my motor using addissimo's chart. (I heard someone say they went by AKG's wiring and it worked, but it seemed a little off to me) Anyways I rewired it and still the same results. I havent checked everything with a volt meter yet. I am getting 1.8 volts to the ECM at this point. So am I correct in thinking, if even one coil is not grounded properly than the ECM will not trigger the fuel pump? I'll keep wrenchin and maby someone has other suggestions.
            • Addissimo
              • Mar 2004
              • 1820
              the dme wont operate with 1.8 volts...
              you need 12 of those volt thingies.
              I'm assuming that pin 6 & 7 are what you're using to determine how much power you're getting to the ecm?
              pins 6 & 7 need to be at 12v.
              which wiring harness are you using?
              • Widebody325
                • 417
                Ok, so I have 12 volts, constant going into the coils, but no voltage coming out of the plug wire.
                • Widebody325
                  • 417
                  I am using a e36 harness. I left the garage for the night, and will get a fresh start tomorrow. Addissimo, thanks for all youre info so far, its been a real big help. I will check again the ecu voltage tomorrow evening now that I re-wired it and got a little better idea of what the problem may be. Thanks again, Ben
                  • KangamangusDriver
                    • Aug 2005
                    • 1870
                    You do have the Burgandy tag 413 ecu correct?
                    • Widebody325
                      • 417
                      My ECU has no stickers on it. All it has is DME raised on the cover. It looks like the stickers were removed.
                      • Jordan
                        • 12913
                        :tsk:
                        • 325Projectz
                          • Jan 2005
                          • 1956
                          Originally posted by Jordan
                          :tsk:
                          91 m3
                          • Widebody325
                            • 417
                            Just called my buddy who sold me the harness and ecu. It is a 413. I am working on the car now, and still no good results. So this is where im at.
                            -All relays are working and getting power.
                            -Coils are getting a constant 12 in one pin, but when turned over nothing in any other pins.
                            -ECU is getting a full 12
                            -I have grounded the coils to the strut tower
                            -injectors arent getting any power
                            • aeryk7
                              • Oct 2005
                              • 616
                              Check to see if you are getting power to your fuel pump just for shits and giggles.If not then check your relays and make sure they are in the right spots the bentley manual has a section for electrical ground wires and power supplys.
                              Also if you have a car with airbag you may want to check your crash sensors the orange sensor pulggins in the engine bay ,if you disconnected them and these are not hooked up the car will think it is in an accident and immobilize.
                              253rwhp
                              My Vids(OLD)
