HELP- M50 turns over, and thats about it
  • permit
    • Mar 2005
    • 3363
    Maybe an EWS-equipped DME?
    That wouldn't allow any spark or fuel.
    • Jordan
      • 12916
      Originally posted by Widebody325
      Just called my buddy who sold me the harness and ecu. It is a 413.
      Red or silver label? Oh thats right you don't know.
      You likely have a late EWSI 413.
      https://mtechniqueabs.com/
      • Widebody325
        • 417
        That makes perfect sense. It sucks that someone took the sticker off so I dont know for sure. Let me see what I can dig up on this ews crap.
        Follow me @baysidefabrication on Instagram
        • Widebody325
          • 417
          So the more research I do leads me to believe that my DME has EWS. So I can either buy a Jim C chip, or preferably a maroon label 413. Anyone have one they wanna sell me?
          • Jordan
            • 12916
            Ahem.. EWSI is easily disabled by jumping a single wire.
            No chip "required"
            • Jason89i
              • Sep 2004
              • 875
              Just called my buddy who sold me the harness and ecu. It is a 413. I am working on the car now, and still no good results. So this is where im at.
              -All relays are working and getting power.
              -Coils are getting a constant 12 in one pin, but when turned over nothing in any other pins.
              -ECU is getting a full 12
              -I have grounded the coils to the strut tower
              -injectors arent getting any power
              ews .... almost guaranteed. had the same problem on my first conversion 2 years ago. spent a month checking continuity, power, signals and grounds. if you have fuel pressure, good compression, the crank position is sending a signal and your getting power as indicated.....id say its ews.
              then i learned about the dreaded silver label 413. swapped ecu's.....drove off into the sunset ....and lived happily ever after.
              cheers, jason
              • Pettas
                • Dec 2004
                • 41
                Care to further explain the way to get around EWS jordan? Btw, dont beleive i've ever spoke to you on aim or forums, you have a sick ass car!
                • Jordan
                  • 12916
                  Well that all depends.
                  1/94 on cars were equiped with EWS I. Very easy to disable, as said a single wire need be jumped and it is for all intents disabled. I wish I could state which wire it is.. but for one... thats not in my best interest, and that of the EWS I owners out there. Also (and more importantly) I can't remember which wire it is.
                  5/95 on cars recieved EWS II, a EWS that actually works this time. Most chip tuners will provide you with a chip suitable for bypassing the EWS and releasing the DME to do engine management stuff.
                  EWSIII is really gay.
                  Thank you.
                  • Widebody325
                    • 417
                    cheers, jason
                    Sick, I have read something about snipping the green wire on pin #66. But I also heard that it dosent work. I think Im just gonna go for the correct DME. Thanks, Ben
                    • permit
                      • Mar 2005
                      • 3363
                      Just do a WTB thread for a stock M50 chip. I'm sure there are several laying around from people that have put in performance chips. Much cheaper than another DME.
                      • Widebody325
                        • 417
                        Umm, a stock chip from maroon tag 413 fixes the problem? I havent heard that yet. I am going to clip pin #66 tomorrow and see if that will work for me. If not, new DME time.
                        • permit
                          • Mar 2005
                          • 3363
                          Any non-EWS chip will make the DME non-EWS, therefore making your car work. A stock chip would sell for like, $20 shipped instead of the $150+ you're going to pay for a new computer.
                          • Widebody325
                            • 417
                            Then I couldent run aftermarket software (ie. AA Stage 2 turbo software)
                            • permit
                              • Mar 2005
                              • 3363
                              Uhhhh, aftermarket software will work. You are replacing the EWS in the DME, so there is no more EWS. AA chip, Turner, MarkD, etc will all work with the DME you currently have.
                              • e30Matt
                                • 5077
                                Before you jump headlong into the ECU stuff, check your power and ground connections on the engine harness one more time. We tried for a good 30 minutes with various relay swapping, etc. on Spoon's car, only to find out we had a power wire grounded by mistake. Hooked 'er up and it kicked over on the first try.
