Working frantically trying to get the car ready for a race this Saturday and need some help-
We ended up using the stock e30 booster and everything seems fine- the issue we're having right now is the throttle cable is frayed on both ends and will be replaced. The routing of the cable seems a little suspect since it's right behind the booster and has to take some interesting turns to get to the throttle body mounting points. Is there a different, maybe longer cable that's better to use with the e30 booster? Is there a better way to route it around the master cylinder?
I think the cable that's there now is from the e34.
TIA
TIA
